Tranny Oil
Old Mar 18, 2005 | 09:49 AM
redline350ZZ's Avatar
redline350ZZ
Default Tranny Oil
Well its time for a Tranny oil change...... is there any product out there that will make the box run smoother??? we run gear oil in the tranny right?????
Old Mar 21, 2005 | 05:32 AM
nearly zer0's Avatar
nearly zer0
Gear oil in the tranny - yes!
Not sure what is out there that works better than stock. its different on different gear boxes. that being said, redline products are generally better than oem fluids in all transmissions. i'm not sure what weights or friction modifiers, etc to use in the 350z however..
Old Mar 21, 2005 | 10:40 AM
G3po's Avatar
G3po
Default gearoil
I run Redline MT90 for Cali + track use. In colder climates some run an MTL/MT90 mix. Note whatever gearoil you choose , make sure "it does not contain friction modifiers". The Z/G 6mT synchros need a little more friction to aid cold shifting operation. The addtion of FMs to the 6MT make it hard to shift when cold , since it makes the synchros too slippery. FMs do ;however, work well in the LSD.
Old Mar 21, 2005 | 11:02 AM
redline350ZZ
I live in HAWAII...does not get cold......
Do you need to flush all the gear oil out??? or will it be ok to have some left in there...since I wont worry about cold weather what would be the best choice....
Redline MT90 ??????
Old Mar 21, 2005 | 11:10 AM
redline350ZZ
Is it possible to change out the LSD oil in the pumkin without removing it?????
Old Mar 21, 2005 | 03:09 PM
dklau33's Avatar
dklau33
Yes, there's a drain and fill plug on the outside of the differential housing. Can't miss it. Needs a 10mm hex bit drive socket.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
