has anyone blown their NA engine? what happened?
Old Mar 22, 2005 | 06:44 AM
sentry65's Avatar
sentry65
the burninator
Default has anyone blown their NA engine? what happened?
Who has blown their NA engine? what happened?
Old Mar 22, 2005 | 06:57 AM
Sins4u33's Avatar
Sins4u33
i think we've only come across hydro locks with N/A motors...not exactley sure but id guess thats about all we have thus far...
Ben Y
Old Mar 24, 2005 | 08:31 PM
ReavTek's Avatar
ReavTek
Misshift. I think there is a video floating around here somewhere... And it happened a few days after a short shifter install.
Old Mar 24, 2005 | 08:40 PM
g356gear's Avatar
g356gear
Some with spun main bearings during track use....lack of proper oiling
Old Mar 24, 2005 | 08:44 PM
westpak's Avatar
westpak
SFZCC
I know of broken rod during an autox probably due to downshift.
Old Mar 24, 2005 | 09:39 PM
___DJK___'s Avatar
___DJK___
Shouldnt the rev limiter protect against something like this?
Old Mar 24, 2005 | 10:20 PM
copba1t's Avatar
copba1t
I believe that the rev limiter can basically only do a throttle kill if it detects you are trying to rev higher than redline. If you misshift and drop into too low a gear your engine will try to match the road speed, and at that point the rev limiter won't matter because the throttle is not even a factor anymore. It's the mismatch in engine and road speeds that is the problem.
Old Mar 25, 2005 | 12:35 AM
jreiter's Avatar
jreiter
Yup, like copba1t said: if you do something like drop it into 2nd gear at 100 mph, it'll break.
Old Mar 25, 2005 | 01:20 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I know someone that did, but I would rather have him admit it
Old Mar 26, 2005 | 10:24 PM
paso007's Avatar
paso007
I believe the Z will know that u r shifting to a lower gear while your road speed is too high for that gear. I have done that once and my Z automatically started to brake and shut off the engine. In fact this has helped me once when there was sudden traffic build up on the highway and I needed to slow down abruptly and if I had just hit the brakes I would have crashed. Downshifting into lower gears while braking helped me go into an incredible smooth stop and my Z stayed in control all the time.
Old Mar 27, 2005 | 05:18 AM
westpak's Avatar
westpak
SFZCC
If you down shift into too low of a gear the car cannot keep you from over revving, you can cut all the fuel you want and brake all you want but if you miss downshift like meaning to go into 4th but go into 2nd and you are going faster than 60, the max speed for 2nd, you are going to over rev, it is just a matter of how fast you are going, the higher you are from 60 the more you will over rev.
Try it, go 100 MPH and downshift into 2nd and see how you probably will go into 9K and brake a rod.
Old Mar 27, 2005 | 03:04 PM
supra crazy's Avatar
supra crazy
That **** happend to me once i was slowing down shifting from 5th to 4th and accidently went in to 2nd, but i caught myself and only reved to like 7500rpm.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
