What performance mods do you "REGRET" doing?
Old Mar 26, 2005 | 02:07 PM
ppw350Zunit's Avatar
ppw350Zunit
Originally Posted by abstrakt
ECU reflash...$600 for a gain of 3rwhp
wow...what a waste of money.
Old Mar 26, 2005 | 02:09 PM
350Zteve's Avatar
350Zteve
Originally Posted by Apexi350z
you sure on the plenum? After the UR Pulley mod, the plenum is the 2nd best mod I've ever done that can be noticeable...
I also noticed a big improvement from the UR Pulley. I could feel the difference the first time I drove the car. The plenum, however, made no difference that I can feel. It doesn't pull any harder to redline that stock. I'm going to keep it though for when I get a turbo kit. The STB however has to go. I'll be fabing up something customer to replace the bar and the heim joints but keep the mounting brackets. I'm thinking of doing something in titanium.
Old Mar 26, 2005 | 03:26 PM
sentry65's Avatar
sentry65
the burninator
you have exhaust, grounding kit, and plenum as your power mods
the grounding kit doesn't do crap so really you just have exhaust and plenum
the fewer mods you have, the less of a benefit the ECU flash will give you. What's your A/F like? send the ECU back to them and say you want more power
Also, 3whp - is that peak power? what's the power in the low and mid range?
Also, you have 19" wheels, did you do your base dyno before or after you put those wheels on? those wheels will make you lose power
Old Mar 26, 2005 | 03:36 PM
abstrakt's Avatar
abstrakt
before and after dyno were done w/stock 17s on...i gained a little more in the mid range...I'd say ~ 5rwhp in some ranges. here's a link to the thread w/my dyno: https://my350z.com/forum/engine-and-drivetrain/113396-disappointed-in-my-dyno-results-after-ecu-reflash.html i've been told by a few people to them adjust my AF ratio and drop it to 13.1...i just figured that they would put it where its supposed to be since they are a tuning shop.
Old Mar 26, 2005 | 04:06 PM
Road Warrior's Avatar
Road Warrior
that sucks...i was going to do this next...what other mods do you have and what year of z?
Old Mar 26, 2005 | 04:44 PM
abstrakt's Avatar
abstrakt
its all in my sig...04 w/RT cats, Injen SES TD and Kinetix Plenum...Based on all this I have officially given up on further bolt on's for my car. i'm going to put my body kit on and my rims and then i'm done w/it...
Old Mar 26, 2005 | 04:59 PM
Road Warrior
i don't blame you....a nice body kit and some rims will be much more gratifying...looks are everything
Old Mar 26, 2005 | 07:41 PM
PhoenixINX's Avatar
PhoenixINX
Originally Posted by 350Zteve
I regret the Crawford plenum and STB. I noticed no gains from the plenum and the STB is a POS. Its rediculous how much you can flex the thing with your hand. Its like a wet noodle.
Why list (brag) it in your mod list then?????? Rather ironic eh?
Old Mar 26, 2005 | 08:51 PM
spf4000's Avatar
spf4000
Have you guys over at Crawford's considered injecting the bar with urathane to increase the rigidity? The stock bar is set up that way, and that bar is way stronger than the one you guys sell.
Old Mar 28, 2005 | 07:00 AM
CESAROTORRES's Avatar
CESAROTORRES
TEST PIPES!!!!!!!!!!!!!!!!!!!!!!!!! RASPY SOUND SUCK!
Cesar
Please visit my web site httP://oZoc.org
Old Mar 28, 2005 | 10:12 AM
bascelik's Avatar
bascelik
Stillen SC -- belts problems, alternator issues, underpowered... I regret not going TT.
Old Mar 28, 2005 | 10:20 AM
NVthis350's Avatar
NVthis350
grouding kit........i wonder what it did?
Old Mar 28, 2005 | 11:30 AM
abstrakt's Avatar
abstrakt
hopefully you didn't pay too much for it...
Old Mar 28, 2005 | 01:39 PM
spf4000's Avatar
spf4000
It made your engine look more complicated.
Old Mar 28, 2005 | 04:19 PM
Sr. Panza's Avatar
Sr. Panza
Uh...the Nismo Radiator Cap?
Old Mar 28, 2005 | 04:20 PM
spdu4ia's Avatar
spdu4ia
AEM cold air. ended up just using the top tube and an HKS filter... could have saved all that money with just the FILTER
Old Mar 29, 2005 | 12:49 AM
ZainT's Avatar
ZainT
buying a CAI and 2 months later buying a TT kit
Old Mar 29, 2005 | 06:36 AM
  #38
mcduck's Avatar
mcduck
Top two for me...
Borla Headers - got them because they were one of the first to market and because I already had the Dual Catback. These made **no** difference in power, only a little throatier. As soon as I was able, swapped them for the Crawford Headers.
TechnoSquare ECU reflash - did not produce as advertised. I don't think it's a bad product. I think it just works better for folks who can take their car directly to them. Check threads to see how many mailed ECUs have gone back and forth 3 or more times. Eventually decided it was more headache than benefit for me and went back to stock ECU... sometimes I miss the 7200rpm redline, tho!
Old Mar 29, 2005 | 07:08 AM
  #39
VandyZ's Avatar
VandyZ
We have some new bar designs in the works, but not of this nature. The new designs will be lighter, smaller, and stronger. Same basic setup though.
The strut bar does exactly what it needs to do. It is stronger than the stock bar for these purposes. The bar is not an aesthetic solution, but a functioning replacement. There is more science involved with the strut bar, than most people understand.
Old Mar 29, 2005 | 08:31 AM
  #40
350Zteve's Avatar
350Zteve
Keep us posted on this. While I'm not happy with my current STB, I respect your shop and the products you make. I would be very interested in a better solution.
One thing I would recommend is doing away with the heim joints. You will never acheive sufficient rigidity when using devices that are specifically designed to move and pivot. Movement is the entire purpose of a heim joint and has no business being in a STB.
If you could do something with some thick wall, rectangular titanium bar stock, that has an oval hole at each end, so you could bolt it in solid, then you'd be on to something. This is what I plan on doing if no other solution presents itself.
