10w-30 right?
Old Mar 26, 2005 | 09:07 AM
ares's Avatar
ares
Veteran
Default 10w-30 right?
is that the right oil type? I can never remember.
Old Mar 26, 2005 | 01:04 PM
nemesisZ's Avatar
nemesisZ
5w-30. It says it on the oil cap.
Old Mar 26, 2005 | 01:29 PM
orhanz33's Avatar
orhanz33
i use 10w30 in wintertime, and 5w30 in warmer weather
Old Mar 27, 2005 | 11:19 AM
pico350z's Avatar
pico350z
Yup, 10 ~ 30W, Valvoline. Good old Nissan oil filter (65F) along with the brass washer is also right for me. Changing the oil yourself is a cinch. Somehow, you need to get underneath the cherished Z. That is a major step and the hardest in my opinion. The second--easy as pie--step is removing the 14 10mm socket screws which keeps a plastic cover that keeps debris, rocks and glass from "bulleting" important components in the oil changing area. Yesterday, I used a friends Rhino Ramps but you need someone to spot you. It is scary going up the ramp--very scary. In fact it is downright weird. Any how, I hope this helps...rich, san jose, ca
Old Mar 27, 2005 | 12:22 PM
Kray Z's Avatar
Kray Z
I would consider the opposite. 1ow-30 for summer and 5w-30 for winter. Either way your dealing with some fairly low centistokes but for in added heat of the summertime i would bump to a higher vis.
but it doesn't matter cause the VI improvers will still get you to a 30w oil when its heated up. Really the first number is the cold number w=winter. The lower the number the easier your engine turns over when it gets super cold out. Use whatever its not a big deal. The 5w was asked by the API and government to the oil companies as a energy conserving oil.
Old Mar 27, 2005 | 01:52 PM
Z CRUZN's Avatar
Z CRUZN
I think you have it turned around there......need heavier weight in warmer weather.......
Old Mar 29, 2005 | 06:35 AM
maximumsportZ's Avatar
maximumsportZ
I live in Florida and never hit below 0, so I use 10w-30.
cashmoney03
Jul 10, 2015 07:06 AM
2007base350z
Aug 31, 2012 06:04 AM
jubes
Jan 28, 2011 11:34 AM
D'sNuts
May 25, 2010 02:25 PM
Sponge
Southern California
Feb 1, 2010 09:08 PM
