Valve body choice for 5AT
Old Mar 31, 2006 | 07:02 AM
  #61
Fairlady_z33's Avatar
Fairlady_z33
I think the VB downtime is like 7 days or 6 days. About who makes it i have no idea but all the reviews that i have seen and read r A+ graded so i think it is worth it.
Old Mar 31, 2006 | 07:12 AM
  #62
blackend's Avatar
blackend
ok how much the price of GB?
Old Mar 31, 2006 | 07:14 AM
  #63
Fairlady_z33
Im trying to get the pricing today i should have an E-mail with the pricing trust me im tryng to do it ASAP i need this mod badly.
BTW the SGP VB video is in the FI forum go check it out.
Old Mar 31, 2006 | 07:32 AM
  #64
blackend's Avatar
blackend
i know that cause i have it but i have 2 VB one which stock and other one is SGP and now i will do the second one
thanks alot Fairlady for the GB
Old Mar 31, 2006 | 09:56 AM
  #65
Fairlady_z33
No problem
Old Mar 31, 2006 | 11:21 AM
  #66
Fairlady_z33
OK we got prices n the time things will be done r being figured out right now.
I pm'd you guys already write back.
Old Mar 31, 2006 | 12:02 PM
  #67
blkblwnZ's Avatar
blkblwnZ
Default Add me to the list
Originally Posted by blackend
1) fairlady_z33 (valve body)
2) ZU L8R (VB)
3) Cesar
4) KraftG35
5) blackend(VB)
6) Oleg
7) Jlimquest
8) MySunset350Z (VB)
9) blkblwnZ
Old Mar 31, 2006 | 12:07 PM
  #68
Fairlady_z33
ok but r you ready when they give me the go
Old Mar 31, 2006 | 05:24 PM
  #69
zzzya's Avatar
zzzya
I haven't seen any actual details, but may be interested.
Cost?
Process - payment and communication with SGP?
Timeline for SGP turnaround - one at a time or all at once?
Last day to get in groupbuy?
Old Mar 31, 2006 | 05:25 PM
  #70
jlimquest's Avatar
jlimquest
I have the TN kit w/ no internal engine mods (354 whp on mustang dyno) & don't drive the car hard all the time. Just once in a awhile (when needed) would like to be able to punch to the floor w/o worrying about the tranny. Would this VB upgrade allow my transmission to safely shift automatically at WOT on Auto mode w/o hitting the rev limiter & risking damage?
Thanks!!!
Old Mar 31, 2006 | 06:46 PM
  #71
MySunset350Z's Avatar
MySunset350Z
what does installing the vb upgrade involve?? is it a diy?
Old Mar 31, 2006 | 07:17 PM
  #72
zzzya's Avatar
zzzya
It is pretty easy to get to. Simply drain the tranny fluid, remove tranny fluid pan (requires 02 sensor support removal), remove plunger for Park and Neutral, remove about 5 or 6 bolts holding the VB in, unhook some wiring (do not drop down the VB to far to fast!!), then reinstall in reverse order. When removing and reinstalling tranny fluid pan, it is best to get new bolts and gasket or be very careful tightening them back down. The tranny fluid is expensive and it will require quite a few quarts at ~$10-12/quart. The Nissan fluid is the only one you can use. Getting the fluid level correct is somewhat challenging as it is best to know the fluid temp to read the crappy dipstick properly. Kinda sucks as you want the fluid level right.
Old Mar 31, 2006 | 07:24 PM
  #73
zzzya's Avatar
zzzya
I did both the VB and TC on my own in the garage on Jack stands. The VB is not that hard but a little scary as a mistake could result in some serious tranny problems. Um, don't try the TC alone unless you are crazy. I got it done but it was not easy as the Auto tranny is pretty hard to manuever, even on a jack, and getting to some of the frickin bolts that hold it to the engine and the wiring harnesses that have to be removed, aaahhh having nightmares as I type. Still took less time than installing the Crawford Headers
Old Mar 31, 2006 | 09:46 PM
  #74
Fairlady_z33
with the power you have maybe first will hit once or twice in AT mode since the tranny is not made for such power and does not reconize when to change but in manual mode you can bet money on it that it will shift as soon as you want.
Thanks!!!
Old Mar 31, 2006 | 09:47 PM
  #75
Fairlady_z33
Just to put it this way the price is really good for the VB or at least to me it is.
Cost?
Ok guys you guys got the price as soon as he tells me ok i will let you know im hoping for the answer on monday to start already this week.
Old Apr 1, 2006 | 05:08 AM
  #76
MMC Racing's Avatar
MMC Racing
Please send me the price also when you get it.. Thanks.
-Mark
Old Apr 1, 2006 | 08:58 AM
  #77
Fairlady_z33
Hey guys quick question is anyone going to do a tranny cooler upgrade becouse i dont really know thw specs on SGP's tranny cooler but i think this one is awsome let me know if you guy r intrested.
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 1, 2006 | 11:39 AM
  #78
rookie's Avatar
rookie
Anyone here know for certain if the FX35 shares tranny compononents with the G/Zs? I know Stillen would do the VB upgrade on my FX if I wanted, I'm looking to the the SGP VB and TC if possible.
Old Apr 1, 2006 | 11:48 AM
  #79
35X's Avatar
35X
Question
With the VB and TC upgrade does the AT shift pattern change? I guess I'm asking is it safer on the tranny to shift in MM vs. auto if your car has FI.
Old Apr 1, 2006 | 12:14 PM
  #80
rookie's Avatar
rookie
Hitting the rev limiter means the fuel is getting cut, you want to avoid this whenever possible. If you ECU hasn't learned down to a slower mode, hitting the rev limiter in Auto with FI is easy and should be avoided.
