Valve body choice for 5AT
Old Mar 27, 2005 | 05:54 PM
Oleg's Avatar
Oleg
Default Valve body choice for 5AT
Stillen or Level Ten? People, please help....
Old Mar 27, 2005 | 07:25 PM
SungNamZ's Avatar
SungNamZ
Level 10 currently has a "core" program for the Valve Body. Not sure if Stillen has one or not. Sure would reduce downtime. If you plan on doing Torque Converter, you will have to send it to Level 10.
Old Mar 27, 2005 | 08:53 PM
Zmego1985's Avatar
Zmego1985
I want to do the Level 10 valve body upgrade, but how hard is it to remove the valve body in the first place. Can someone please explain to me how you remove the valve body, because im scared i could damage the tranny.
Thanks Glen
Old Mar 28, 2005 | 05:59 PM
bullseye's Avatar
bullseye
Stillen does not have a core program. They send you a box and packing, you remove your stock VB and ship it to them, they modify it and return it to you within 48 hours. Other than this inconvenience, I have not heard anything bad about the Stillen VB mod.
From what I've read about the Level10 VB mod, it shifts pretty hard. Some folks might not like hard, neck-snapping shifts just going to get milk...
Pick the "lesser of two weevils."
Old Mar 28, 2005 | 08:55 PM
shinz's Avatar
shinz
Anyone w/o FI have this? does it shift hard enough on the 1-2 shift to chirp the tires without any FI? thanks.
Old Mar 28, 2005 | 09:37 PM
350Zum's Avatar
350Zum
How much is each one?
Old Mar 29, 2005 | 04:02 AM
PumpedVA's Avatar
PumpedVA
I am having this done right now and will let you know
Old Mar 29, 2005 | 09:25 AM
wfcall's Avatar
wfcall
I've done the level Ten upgrade on an '04 with ATI-I'll try to answer your questions.
It does not shift that hard-at part throttle and medium throttle shifts the shift IS frim but is not going to "chirp" the tires. The cars not in boost at this point anyway so the fact thats it's F/I I don't think is relevant.
It's VERY easy to pull the valve body;
Drain fluid
Pull pan
Remove bolts on Valve body
Unplug wires
I had it back in less than a week without doing a core.
Old Mar 29, 2005 | 09:05 PM
MySunset350Z's Avatar
MySunset350Z
i've already done the edge racing TC upgrade. which would be a better way to go? level 10 or stillen?
i can spin in 1st and chirp 2nd N/A as it is. but i still dont like the soft fluffy shifts.
we need some pics on how to romove it. would be nice.
Old Mar 30, 2005 | 11:26 AM
rabbid's Avatar
rabbid
I know that Stillen was having some trouble at firts when they went to release there Valve body. So I haven't had any experiance with there's. I have done several of the Level 10's I would say just call Sammy over there and he'll get you set up. I haven't had any complains. Still will not shift fast enough to prevent FI cars from hitting Rev limiter
Old Mar 30, 2005 | 11:32 AM
SungNamZ's Avatar
SungNamZ
Might want to consider getting ECU "Limited Flash" from Technosquare to avoid "hitting Rev limiter". Limited Flash increases rev limit to 7100, removes speed limiter and gives you 100% throttle Vs 85%.
Old Mar 30, 2005 | 01:04 PM
rabbid's Avatar
rabbid
You will still hit the rev limiter at WOF
Old Mar 30, 2005 | 01:28 PM
MySunset350Z
whats the deal with 85% vs 100%?? you mean the car isnt really at WOT when you have the gas pedal pushed in all the way?
Old Mar 30, 2005 | 02:06 PM
SungNamZ's Avatar
SungNamZ
I would suggest that you visit the Technosquare web site, where you can read about the "drive by wire" in the "Z" that restricts fuel. www.technosquareinc.com You would have to confirm with Technosquare, but apparently while in the "auto mode", by increasing the rev limit, there is time for the shift command to get to the transmission before you hit the rev limit in WOT.
Old Mar 30, 2005 | 07:30 PM
MySunset350Z
i see what you mean now. thanks.
Old Mar 31, 2005 | 09:55 AM
Street Visionz, Inc.'s Avatar
I'm interested in hearing reviews about the stillen vb upgrade. Maybe if its good we can get a GB going on either valve body? I'd be down for sure.
Old Mar 31, 2005 | 10:00 AM
johanna1's Avatar
johanna1
I have talked with SGP and know they have a car with a auto they have done with TT and has a SGP Valve Body on it that shifts it great. They also carry torque converters for the Z. I am looking into them since they are pretty well know for there fast Z's.
Old Mar 31, 2005 | 10:47 AM
SungNamZ's Avatar
SungNamZ
I also heard some GOOD things about SGP and have talked to SGP about the VB and TC upgrade. They advised me that they do not do the work in-house. So, where do they send it to have the VB and/or TC upgraded?
Old Mar 31, 2005 | 12:01 PM
rabbid's Avatar
rabbid
I think most go through Level 10. They certainly have a proven track record
Old Mar 31, 2005 | 10:08 PM
black350's Avatar
black350
i remember there being a thread about lvl 10 being kinda bad in the customer service area...
