Colder A/c Anyone ??? :)
Old Apr 18, 2005 | 08:20 AM
KWIKZ's Avatar
KWIKZ
Thumbs up Colder A/c Anyone ??? :)
heres a tip for colder ac,
all you have to do is disconnect the two hoses going from engine compartment firewall) to heater core inside the dashbord..then connect the two hoses together ...
so what you are doing is stoping hot water from entering passenger compartment
good luck
Old Apr 18, 2005 | 08:44 AM
protocav's Avatar
protocav
true...but then you loose your heater.
Old Apr 18, 2005 | 08:58 AM
KWIKZ's Avatar
KWIKZ
i never use the heater so it works out
you could always get a valve that can open and close and stick it inline...
Old Apr 18, 2005 | 09:16 AM
sentry65's Avatar
sentry65
the burninator
sometimes it's useful to run the heater to cool the engine
think about track days...
Old Apr 18, 2005 | 02:44 PM
KWIKZ's Avatar
KWIKZ
actually stock cooling system is great my first mod was the nismo thermostat my temp gauge only moves like one millimeter above cold and always remains below the first line
Old Apr 18, 2005 | 03:48 PM
sentry65's Avatar
sentry65
the burninator
yeah i have one of those also, along with a koyo radiator
my temp gauge hasn't ever gone out of hand yet even on a track day
I'll have to think about if I want to try what you did though since here in AZ it's hardly ever cold and my engine warms things up pretty well anyway.
how much cooler is the AC?
I thought the Z's AC was pretty cold as is - nothing wrong with even colder though of course
Old Apr 18, 2005 | 04:15 PM
KWIKZ's Avatar
KWIKZ
oh man its ALOT colder now...
easy 10 min install i love it.
Old Apr 18, 2005 | 05:23 PM
DavesZ#3's Avatar
DavesZ#3
I'm not seeing how the A/C can be any cooler with the heater disconnected. The only way that is possible is if you turn the thermostat up from the coldest setting. If you don't have the temperature dial set all the way down on 60° then you're using the heater to warm the air so it's not quite as cold.
Old Apr 18, 2005 | 06:41 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
How difficult is it to connect the hoses? If it isn't that tough...i'll just do it for the spring, summer, and fall and put it back for the winter.
Old Apr 19, 2005 | 04:09 AM
DavesZ#3's Avatar
DavesZ#3
The actualy disconnect and reconnect may not be difficult but you have to be careful to bleed any air that gets into the system. If you've seen the posts here by people who have replaced their hoses, a common problem is overheating as a result of there being a small amount of air left behind.
Why not just cut the hose and install a stopcock inline. That way you can close it in the summer and open it in the winter.
Old Apr 19, 2005 | 07:03 AM
KWIKZ's Avatar
KWIKZ
Dave you cool the heater pipes in your vent area cold a/c air passing thru wont get affected by it.
you will appreciate it even more after parking in the sun all day you get quicker cool downs
Old Apr 19, 2005 | 07:18 AM
KWIKZ's Avatar
KWIKZ
it is not very difficult all you need is a foot long 5/8 heater hose and two 5/8npt hose connectors remove the two hoses from firewall and add the extension thats it.
now hot water will circulate in the engine compartment and not inside the car
i think your best bet is to find some kind of stopcock valve like on the old chevy trucks and just cut the stock hose and add the valve.just make sure you cut the hose going from motor to passenger area and not the hose thats going from passenger area back to water pump
Old Apr 19, 2005 | 08:54 AM
donricouga's Avatar
donricouga
I must have a freak 350z cuz my AC is ****ing Cold !!! I have to shut it off half the time
Old Apr 19, 2005 | 09:37 AM
sentry65's Avatar
sentry65
the burninator
i'm just wondering if there's any sorta side effects from doing this
during the winter here it's never THAT cold and the Z's engine warms up my car a little anyway - and I can always throw on a coat or something so I'm kinda considering this.
The summers are always brutal here....
Old Apr 19, 2005 | 12:52 PM
KWIKZ's Avatar
KWIKZ
its not permanent if and when you need heat then pop the hood and open the faucet ..
35reilly
Sep 28, 2015 07:42 AM
papo470
Aug 6, 2003 07:26 PM
emu29
Jul 16, 2003 07:51 PM
kozik
Jul 15, 2003 05:26 AM
