my fu&^ing Z is an underpowerd POS :(
Originally Posted by axxizzer
the Z is noticably faster after the break in period. I have sen Dynos of a 20 WHP difference between 8 miles and 4K miles.
Also, the 300C is 4K pounds, not 5K
uhh...I didnt say it was slow. If anything, I just told him it was faster than he thought. No need to correct me.
Dude chill, I wasn't correcting you, geez
Originally Posted by sentry65
agh, i'm not even going to get into the ECU, but I thinking if you have an APEXI SAFC II and the O2 cat sensor fix that pulls the sensors out of the pipes to avoid bad emissions reading, the ECU won't be locked...
otherwise, you THOUGHT bolt ons would give you MAJOR gains. Meaning you didn't know what was up with the car in the first place
BTW, I'm at around 345 crank hp with bolt ons...
rite now i have test pipes and cold air i feel i lost a **** load of low end torque
i dont see how i can make it run rite without some kind of tuning
Originally Posted by zand02max
Jus curious how old you are?
oops sorry im 27 i had a 98 c5 sold it rite now my chevy truck is supercharged and my durango has all the bolt ons
when i get on it in the Z it just dosent plant you in your seat like my other cars
You went from an LS1 (98 C5) to a VQ35DE (Z) and expected it to be faster?
Honestly, you should have searched around a little bit.
Did you not test drive the Z?
I loved my Z, but my Grandpa's old C5 would stomp it.
Set aside 5g for a blower or even more if you want to turbo it.
If you want to go N/A be prepared to spend near the same and you'll reach near 300 rwhp.
Be warned though you have to pay big to play big with this car.
P.S. - If you want torque back, but on some highflow cats and take that CAI off.
I had Nismo CAI and test pipes, and felt I lost grunt.
no i didnt expect it to be faster than a vette but i think nissan should have set the bar a bit higher on the power to weight ratio what were they thinking
after the test pipes and cold air (AEM)i feel i actually lost power due to the PCM not wiling to compensate
are you saying that the cold air intake and test pipes affected your low end i think you might be rite thats exactly what i felt
you need to reset the ECU if you don't have a way to permanently fool the ECU or bypass it with an EMS
test pipes especially are brutal on emissions - all the ECU ultimatly cares about are emissions. It's a downward spiral. The ECU will reduce fuel because the O2 sensors are detecting bad emissions. If it can't bring the emissions down enough, it'll keep reducing fuel. Eventually, it'll start knocking. If it knocks, it will start pulling timing. Then if it's not enough emissions reduction, it will cut more fuel.....and on and on. Until it reaches an equilibrium, or can't go any further, at chich point it throws a SES code and goes into safe mode. If emissions are drastically out of spec and can't reach an equilibrium with emissions level, it will go into limp mode - and you will KNOW when that happens. You won't be able to rev above 2500 and all the lights on the dash will light up.
At the very least do something about the O2 sensors in the test pipes. There's all sorts of proven ways to pull the sensor out of the pipe so it's not directly in the way of the exhaust
BTW of course you lost some low end torque with test pipes - you're NA. You don't have as much back pressure. Without some form of FI, you're not going to get the same sort of back pressure levels down low. Up in the high RPM's you'll gain power, but not down low. That's test pipes 101 sorta info...
I wouldn't be suprised if the 05 is even more of an emissions *****. Of course the 05 track model has less torque than the other previous models...
I agree with you, the Z, 100% stock kind of "feels" slower than what you would expect. Did you bring it to dragstrip? What where your times? Trap speed?
