Nismo Clutch + JWT flywheel
Old May 25, 2005 | 11:16 AM
faris13's Avatar
faris13
Default Nismo Clutch + JWT flywheel
I tried to search for this setup and couldnt really find any reviews. Does anyone have this setup? If so what are your impressions and is there any problems is using these two brands together??
Old May 25, 2005 | 12:00 PM
Jaki's Avatar
Jaki
I've heard of people running the Nismo Flywheel with the JWT clutch and they said it runs just fine, but I haven't heard of anybody with the JWT Flywheel and Nismo Clutch... why not just go with the same brand for both?
Old May 25, 2005 | 12:41 PM
faris13's Avatar
faris13
yea now im not sure which it was but for instance i think the jwt setup is about 33-34 lbs total while the Nismo+ JWT setup is about 30lbs.
Old May 25, 2005 | 01:11 PM
RA11325's Avatar
RA11325
I have wondered the same thing, i know its the lightest non-tilton setup, but i have been curious as to how much power the nismo clutch will hold.
Old May 25, 2005 | 06:29 PM
Z BOY's Avatar
Z BOY
jwt clutch has more holding power, like 1200 vs 1050 ft-lb. nismo fw lots heavier, 23 vs 14lb.
i've read the setup you describe is the most street-friendly in that you can slip it the most.
Old May 26, 2005 | 07:48 PM
TX-Ruben's Avatar
TX-Ruben
I'll do a review next week after my install.
Old May 27, 2005 | 08:34 PM
Armitage's Avatar
Armitage
Stock Flywheel = 28 lbs (maybe 27?)
Nismo Flywheel = 23 lbs
JWT Flywheel = 14 lbs
9 lbs may not sound like a lot, but it is with the flywheel.
Old Jun 1, 2005 | 11:30 AM
faris13's Avatar
faris13
hey tx-ruben did you get it installed yet? i haven't found anyone yet with this setup.
Old Jun 1, 2005 | 06:11 PM
TX-Ruben's Avatar
TX-Ruben
Not yet, the holiday weekend hosed my timing up. Early next week... making an appointment tomorrow.
Old Jun 1, 2005 | 07:42 PM
lovetoclown's Avatar
lovetoclown
The lightest of the two is the JWT flywheel and Nismo clutch. But if you are going FI, then go JWT for both. Either way the engine will rev and drive better than stock. I have the JWT setup and love it. Very easy to drive, no noise and made it alot more fun to drive.
Old Jun 4, 2005 | 11:30 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
NISMO CLutch is LIghter then the JWT...
JWT is about 23/24 lbs... NISMO Clutch is 21lbs...
remember... the clutch bolts to the flywheel..
Old Jun 5, 2005 | 04:09 PM
RA11325's Avatar
RA11325
How much power can the NISMO clutch hold?
Old Jun 5, 2005 | 04:48 PM
Jason@Performance
Performance Nissan
Close to 420 to the wheels...
Keeping in mind this is a clutch that is in good condition...
no matter the clutch, once it is worn, wont hold as much as in its prime..
Old Jun 6, 2005 | 11:56 AM
blinkygab's Avatar
blinkygab
Hey Jason - thanks for your help this weekend.
He got me this JWT flywheel + NISMO clutch set up this weekend, installed this past Saturday.
The throttle is MUCH more responsive and sensitive, but doesn't rev fast like a bike, or anything close to Jason's Tilton.
I have a 03 Track, and the clutch pedal force is now much lighter - easier to press down.
Engagement or catching "range" of the clutch is slightly smaller than stock, but this thing is still easy to drive/launch.
There is ZERO fear of stalling, even from a dead stop going up a hill. The clutch slips IDENTICAL to stock.
There is some "cement" sound at idle and under 2500rpm, but it's so subtle, and sounds rather cool.
As for performance, the car pulls harder through the redline and out of turns - the car is definately more nimble and faster. I'm happy with the performance characterstics, but for $1,350 installed, I'd recommend this upgrade only if you're in need of a new clutch or done with your all other suspension and other cheaper go-fast parts.
I've been torn between choosing the Tilton Full-Street and JWT+Nismo for a while, and came down to the following choice:
1. go for Tilton if you drive your Z like it's a Race car almost 100% of the time. Tilton's issue with sound (cement / squeal) are quite minor IMO, and seems exaggerated in the reviews. However, drivability from dead stop seems like a continuous challenge.
2. go for the JWT+Nismo if you want a "normal" car feel, but an improved response from your throttle. You will have a *slightly* quicker, civil Z - a ride that your girl will still appreciate, and your buddies could still drive.
Old Jun 6, 2005 | 12:12 PM
TX-Ruben's Avatar
TX-Ruben
Cool, you beat me. My set-up gets installed Thursday.
Old Jun 6, 2005 | 06:55 PM
Z BOY's Avatar
Z BOY
blink, thanx for the review. did you pick the nismo over the jwt clutch cuz its lighter? you didn't care about the greater hp capacity of the jwt clutch?
Old Jun 6, 2005 | 06:57 PM
Z BOY's Avatar
Z BOY
oops, wrong units. that's 1200 vs 1050 kg, iirc.
Old Jun 7, 2005 | 07:36 AM
faris13's Avatar
faris13
damn it!! now it's time to beat on my clutch lol. i know it's pretty expensive but im can't wait to see how this mod and my 3.9 final drive change the feel of the car. Thanks for the reviews guys, i think this is the setup im gonna go with.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
