What are Symptoms of Knocking?
Old May 26, 2005 | 09:40 AM
GTO2350's Avatar
GTO2350
Default What are Symptoms of Knocking?
What are some symptoms of knocking? i've heard that studdering during engine load is one i've also to heard to listen to pinging the thing is the z makes so many noises how do you distinguish pinging noise???
thanks in advance.
Old May 26, 2005 | 10:30 AM
Balls's Avatar
Balls
You're on the right track so far. Unfortunately, the sound is hard to find in the sea of noise that this car produces. ESPECIALLY if you have exhaust.... which many of us do.
Usually what I do to calm my nerves is to drive close to a wall of some sort that will reflect the sound of the car back at me. Focus on the sound of induction from the engine and hit the gas.
If you don't already know what it sounds like, just imagine a ballpeen hammer stricking a thick slab of metal. The thing is, once you've heard it, you'll never forget what it sounds like. You may have even heard this sound already, but you didn't know it was pinging... so if you think of an old klunker puttering around struggling to get up a hill... the sound may come to mind.
Anyway I hope that helps.
Old May 26, 2005 | 12:08 PM
PerfectOddz's Avatar
PerfectOddz
Detonation can sound different depending on the severity and even the type of engine. As you said, with all the other noises going on it can be hard to distinguish sometimes.
If it isn't really bad, I think it sounds like a bunch of BB's being shot into the bottom of a coffee can.
Old May 27, 2005 | 09:30 PM
GTO2350's Avatar
GTO2350
does pinging or knocking make the same sound as when you get shocked by static?
Old May 28, 2005 | 01:32 PM
weslutes's Avatar
weslutes
Yes, an electric shock is close. Steve Millen described VQ35de ping like a sewing machine. A few weeks ago I heard my friends PE TT make the sewing machine sound, I told him and he took it to the shop right away for a quick fix(re-tune).
The sound is very light and hard to catch sometimes but once you know the sound you'll never forget it.
Old May 28, 2005 | 01:39 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
Like a sledge hammer to the pistons and rod. Not a beautiful note.
There should be hesitation as well with knock.
weslutes's Avatar
weslutes
Old May 28, 2005 | 06:09 PM
GTO2350's Avatar
GTO2350
The strange thing is i only hear it on the left hand side and only when im passing those planters that divide streets. and only when drive pass the planters and after i pass the planters the sound disappears.
Old May 31, 2005 | 10:38 PM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
You can use PLX R500 for monitor you knock count and there's a headphone output for you to listen to knocks.
pslamp32
Feb 8, 2017 09:07 AM
Brantwilliams13
Sep 16, 2015 05:03 AM
Inspatatrac
Sep 8, 2015 02:12 PM
saccorator
Mar 9, 2003 08:57 PM
montemac
Feb 19, 2003 05:52 AM
