3.9 final vs. stock?
Old Aug 1, 2005 | 08:45 PM
faris13's Avatar
faris13
Default 3.9 final vs. stock?
just curious to see if anyone's lined up a stock z vs. another z modded only with the swapped final drive???
i installed my 3.9 a while a go and i can defiately tell a difference...just wanted so see if anyone raced em yet?
theoretically the 3.9 final drive should reach the limited top speed quicker that a stock car. So it would be cool to see them line up
Old Sep 2, 2005 | 12:34 PM
dragonplayboy's Avatar
dragonplayboy
yeah, i want to know, I've heard there's only a .2 second difference in top speed, which sure ain't worth my 1500 dollars! let me know if you find out man
Old Sep 2, 2005 | 04:47 PM
da45king's Avatar
da45king
uh no....If you where to drag it out to 155mph...the car with the 3.9....would be a football field ahead in the end 6 gear under normal cirmstance is a dog...
Old Sep 2, 2005 | 05:16 PM
Machupo's Avatar
Machupo
IIRC, the .2sec difference is in the 1/4, but is due to the fact that the 3.9-enabled car has to shift into 5th...
Old Sep 3, 2005 | 06:12 AM
ZXiMan's Avatar
ZXiMan
I dropped .5 second in the 1/4 mile with the 3.9 gears
But I also have A LOT of mods...
cold air intake mod (A 4" hole cut out in the plastic shroud right in front of the filter), JWT popcharger, ported throttlebody (just a clean up), ported Crawford plenum, Crawford headers, Crawford high flow cats, Fujitsubo Legalis-R exhaust, evo350 3.9 gears....
ran a best of 13.37@104 mph...
I can make it through the traps in 4th gear (6900-7000 rpm)
I have 7200 rpm to work with though
The gears drop the rpm right in the sweet spot on the rev-up engines and I think it explains the acceleration difference...
These gears made a HUGE difference on my '05 6MT G35 Sedan!
Old Sep 3, 2005 | 06:24 AM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
It's a very very good mod especially if you plan to remain NA i definately recommend that anyone doing na would get this it really does make a big difference and is worth the money imo but it's all up to the buyer
Old Sep 3, 2005 | 11:55 AM
Resolute's Avatar
Resolute
I think with the higher redline, like with the new 300hp engines, this would be a great mod. With the 6600 redline, this could just make you smack it that much more often with little gain in the 1/4. I would like to check one out on my local road courses though, I imagine that is where it would really shine, and not so much the 1320.
Will
350z82
Oct 1, 2015 06:25 PM
