B&M Short Shifter 1st Version - Recall?
Old Aug 17, 2005 | 07:39 PM
eric1900's Avatar
eric1900
Default B&M Short Shifter 1st Version - Recall?
I have B&M Short Shifter purchased from local performance shop about 6month... And I hear some other Z forum community that B&M company recalling all 1st V. shifter... is that true? any opinion..
Old Aug 18, 2005 | 07:59 AM
Chebosto's Avatar
Chebosto
if you're not having any issues with it, then keep it. the 'recall' is only for those that have issues with the reverse knub being rubbed down.
Old Aug 23, 2005 | 08:23 PM
eric1900's Avatar
eric1900
So, it is 50/50 ? or it does happen to all Z's ?
Old Aug 24, 2005 | 07:37 AM
Chebosto's Avatar
Chebosto
You can see the difference, left is older design, the right is the newer one
when installed the pin should look like this, with the top of the knub flush with the brass plate when moving to like 5th or 6th:
Old Aug 24, 2005 | 10:08 PM
eric1900's Avatar
eric1900
So..if I have new Version shifter, I'm safe right? I won't have any problem with that rubbing or grind with installation plate
Old Aug 24, 2005 | 10:15 PM
Chebosto's Avatar
Chebosto
yes. you should be ok. after driving for a few hundred miles. take off the plastic cover, and RETIGHTEN the brass plate so it wont move out of place, that may prevent any issues of getting into Reverse or what not-
Old Sep 19, 2005 | 08:34 AM
tcn75's Avatar
tcn75
I have the 1st version ... anyone know where B&M dealer in dallas, TX so I can go for exchange? thanks
Old Sep 19, 2005 | 11:04 AM
tcn75's Avatar
tcn75
talked with B&M .. there was no recall for the 1st version. But there was a change. If you have 1st version + the recieve, you can mail the shifter back to B&M to modify without no cost. No recieve = no luck. I bought mine a year ago
Old Sep 19, 2005 | 11:31 AM
Chebosto's Avatar
Chebosto
if ur having an issue with it, and the knub from version 1 is rubbing down, then yes you should ask for a service.
otherwise, if u have no issues and the **** is not wearing, then they're not going to replace it since it's not defective.
Old Sep 19, 2005 | 11:35 AM
tcn75's Avatar
tcn75
yes I have that issue, and its hard to shift to 5th gear too. When you said "ask for a service" what kind of service and who should I ask ? B&M authorized dealer or bmracing.com contact list ?
Old Sep 19, 2005 | 11:58 AM
G352NV's Avatar
G352NV
Side note. I have my tranny out and Ive thought about doing this mod. Is it worth it?
Old Sep 19, 2005 | 12:04 PM
tcn75's Avatar
tcn75
not to me ... even if you have 2nd version, you still have to deal with rattle problem.
Old Sep 19, 2005 | 01:14 PM
Chebosto's Avatar
Chebosto
rattle to B&M isnt an 'issue'.. it's the rubbing of the shifter block.
you should contact B&M directly in California. i'm not sure if their dealers would do anything about it.
Old Sep 20, 2005 | 10:56 AM
tcn75's Avatar
tcn75
Wonder if anyone can let me have a copy of the recieve for the B&M short shifter ??
B&M will not upgrade my short shifter version 1 to version 2 if I dont have the recieve. I lost mine. I bought it 1 and 1/2 year ago ... my fax # is 972-656-2812. Please help thanks!
Old Sep 20, 2005 | 01:57 PM
tcn75's Avatar
tcn75
nvm ... i found my receipt ...
Old Oct 9, 2005 | 08:41 PM
tcn75's Avatar
tcn75
got the 2nd ver. , much better, but still rattle when i hit 3k rpm, but the rattle gone when it hti 3.5k rpm. weird. I think the reason that cause b&m short shifter rattle is because its made of 2 pieces, (while rouge and stock one only made by 1 piece), the rattle is at the join of that 2 pieces, no relates to the shift *** thought. (I took the shift *** out, went for a ride and still hear the rattle)
07ZEKE
Aug 23, 2021 09:15 PM
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
