EVAP Emission Control System Leak (SES CODE)
Old Aug 22, 2005 | 03:17 PM
wadd3456's Avatar
wadd3456
Default EVAP Emission Control System Leak (SES CODE)
Anyone have an idea of what specifically to look for in regards to this code?
P0442 EVAP Emission Control System Leak (small)
Is there a troubleshooting guide that can pin down specific hoses and what-not to check?
Old Aug 22, 2005 | 03:41 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
gas cap? and then check all the hoses around the fuel rail/evap purge solenoid.
Old Aug 22, 2005 | 04:53 PM
wadd3456's Avatar
wadd3456
Err, I cant find me dang service manual. I had it in PDF from 3 yrs ago and now I cant find it!!!
Anywho, I didnt see/hear anything out of the ordinary. I heard one hose but took it off and it had no cracks or holes. Car only has 9k miles on it haha.
What is that EVAP service nipple for? Could this have anything to do with it?
Old Aug 22, 2005 | 07:07 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
do you have a Greddy EVO 2 exhaust?
Old Aug 23, 2005 | 03:44 AM
wadd3456's Avatar
wadd3456
No, I do have a Borla True Dual though.
Old Aug 23, 2005 | 05:57 AM
Sharif@Forged
Forged Performance
The service nipple will not leak. Have you tried resetting the code to see if it returns? Maybe it was a fluke??
So are you saying you have never touched your fuel rail or EVAP lines? Or your fuel pump assembly??
Old Aug 23, 2005 | 06:49 AM
MaximumHP's Avatar
MaximumHP
It could be any of these:
-Incorrect fuel tank vacuum relief valve
-Incorrect fuel filler cap used
-Fuel filler cap remains open or fails to close.
-Foreign matter caught in fuel filler cap.
-Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve.
-Foreign matter caught in EVAP canister vent control valve.
-EVAP canister or fuel tank leaks
-EVAP purge line (pipe and rubber tube) leaks
-EVAP purge line rubber tube bent
-Blocked or bent rubber tube to EVAP control system pressure sensor
-Loose or disconnected rubber tube
-EVAP canister vent control valve and the circuit
-EVAP canister purge volume control solenoid valve and the circuit
-Fuel tank temperature sensor
-O-ring of EVAP canister vent control valve is missing or damaged
-EVAP canister is saturated with water
-EVAP control system pressure sensor
-Fuel level sensor and the circuit
-Refueling EVAP vapor cut valve
-ORVR system leaks
I'd check the gas cap, and re-set the code. More common problems in the evap system are the control valves like the canister vent valve, and purge valve. this one can be a hard one to find sometimes.
Old Aug 23, 2005 | 08:51 AM
wadd3456's Avatar
wadd3456
Wow, thats a scary large amount of vauge problems it could be. I checked the gas cap then disconnected the battery for 30seconds and reconnected. Is this enough to reset it? If so, it came back on regardless.
Do you have a pic of the control valves (canister vent valve and purge valve). Purge valve sounds like what I was describing above. Do I have to purge it or something?
Sorry for all the questions. I just want to avoid brining in my car to the dealer. Ive gone 3 perfect years witout visiting them, and dont want to screw it up now.
Old Aug 23, 2005 | 10:19 AM
Sharif@Forged
Forged Performance
You need to reset that code with a scan tool. Or unplug the battery for 12-24hours.
Old Aug 23, 2005 | 11:20 AM
wadd3456's Avatar
wadd3456
oh really? I didnt realize the scan tool would reset it.
Old Aug 23, 2005 | 02:44 PM
wadd3456's Avatar
wadd3456
Ok, I reset it with the scan tool..........started the car back up and let it sit in the garage running. So far, no problems. Tomorrow (which is the day my warranty expires) I will drive it to work to see if it returns. If not, then Im crossing my fingers it stays GONE!
Thanks for your help
Old Aug 24, 2005 | 09:38 AM
MaximumHP's Avatar
MaximumHP
Hopefully it was just a fluke thing. If you have the service manual, there is a procedure in there for testing if it returns Otherwise, PM me I can send you the relevant pages (It's kinda long).
sales@czp
Sep 23, 2019 03:30 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
