Dynoed on Mustang dyno ..... Please reply.
Old Sep 15, 2005 | 04:21 PM
350ZRB's Avatar
350ZRB
Default Dynoed on Mustang dyno ..... Please reply.
I got 179 HP and 181 TQ. It kinda low. I know you can not compare dyno to dyno. But what number do you got?
Thanks
Old Sep 15, 2005 | 04:24 PM
westpak's Avatar
westpak
SFZCC
Was it a Z or an RX8?
Sorry the numbers seem way off.
Old Sep 15, 2005 | 04:59 PM
homiusang's Avatar
homiusang
No way it's a RX8 with that torque #, it's gonna be a Cobalt SS or SRT-4
Old Sep 15, 2005 | 05:00 PM
DomZ's Avatar
DomZ
I dyno'd 227whp on a Mustang dyno....
Stock
Old Sep 15, 2005 | 06:22 PM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
Thats pretty low even for a Mustang dyno.
We see around 210-220 whp and tq on our Mustang.
Tom
Old Sep 15, 2005 | 08:09 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
what kind of map were they running?
do you know the weight setting they had for your car / rollers?
on mustangs software you can punch in all kinds of different numbers to simulate different loads...
you can even simulate 1/4 mile runs and also simulate a dyno jet type run...
some people swear by them since you can imulate all types of scenarios... with a semi truck for example you can simulate trailing a huge loaded trailer...
Old Sep 16, 2005 | 02:29 AM
neffster's Avatar
neffster
LOL. Nice jab at the RX8 crowd.
Old Sep 16, 2005 | 10:17 AM
UnderPressure's Avatar
UnderPressure
Need more details to determine what is going on. Something is wrong.
Old Sep 16, 2005 | 11:38 AM
350ZRB's Avatar
350ZRB
He put in 3500 lbs for the car weight.
I will post the graph later. He does not seem to know how to dyno well.
Thanks
Old Sep 16, 2005 | 02:45 PM
anotheraznguy's Avatar
anotheraznguy
hmm... i went to the dyno.. and the dude put in 3800 goddamn curb weight..
mind you this was on a 4wd mustang dyno.. it mad 212.something
and then he changed it to 3400
and it made 213.something
so not much change.. eh!
Old Sep 18, 2005 | 08:05 AM
UnderPressure
Mustang uses the curb weight of the vehicle to determine the resistance it applied via the retarder. The other value is hp @ 50mph. By using these 2 variables the dyno calculates the load to apply to the rollers to "simulate" world type conditions. On n/a and supercharged cars these values don't have much bearing on the power numbers. Turbo cars it can affet the spool rate of the turbos.
I'm guessing on the firstcar the dyno operator had the parasitic drag value set incorrectly. This is a value the operator must cnage when running the dyno in 2wd or 4wd mode. Mustang dynos require the operator to manually change alot of variables when switching between 2wd & 4wd. Somtimes they don't get changed or get miskeyed on you get really funky numbers.
Old Sep 18, 2005 | 09:25 AM
350ZRB's Avatar
350ZRB
Thanks for info, underpressure.
I don't know how to insert the graph. But here is the info: 3200 lbs for weight and 13.59 HP @ 50 MPH. 179.8 HP @ 6000 RPM and 180.9 TQ @ 4000 RPM. The graph looks smooth like flatten "X" (HP line is climbing while TQ line is dropping)
Old Sep 18, 2005 | 06:38 PM
booger's Avatar
booger
3,200lb's would be a little light on the Wt., you need to add in the drivers Wt. , and any other mods that added WT. .Unless you have done some Wt. saving mods . We put in 3700lb,s for my G35
Old Sep 19, 2005 | 09:42 PM
Gruppe-S's Avatar
Gruppe-S
13.59HP @ 50mph is a little bit high I think. I know it's probably the EPA recommended, but it tends to skew the numbers. Also was a weather station attached? If so that can skew the numbers more!
Keep in mind - a dyno is a tuning tool - there are just too many variables from dyno to dyno to really be able to compare numbers.
Cheers,
Gary
Gruppe-S
Old Sep 20, 2005 | 04:21 AM
da45king's Avatar
da45king
I sure hope you weren't charged for that nonsense....The only thing you get from that dyno is: questions about the test equipment and its operator;test subject (350z) is immune from scrutiny.
Old Sep 20, 2005 | 04:33 AM
350ZRB's Avatar
350ZRB
$75 for 3 pulls. That's sux. I know I shouldn't go there in the first place. I just want to see the number after all my N/A mods.
Injen CAI, SSV IM, DC headers, Kinetix Cats, Borla TD.
No ECU reflash.
I don't think weather? station is attached.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
kyin
Oct 15, 2015 05:54 AM
seagrasser
Oct 11, 2015 03:27 PM
Alexreyes
Sep 30, 2015 11:30 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
