Installed Rouge Short Shifter today
Old Sep 18, 2005 | 09:43 PM
Faizei's Avatar
Faizei
Default Installed Rouge Short Shifter today
I installed my Rouge short shifter today and fell in love. The shift was so precise and smooth. Install was so easy and was done within an hour. Never had a short shifter before, but will be getting one for all of my cars from now on. Didn't expect it to make that much difference.
I had one problem though and need your help. After screwing back the bolt from the bottom of the car, I could not get the rubber cover that protected the bolt, which held the shaft in place, to go back on. Is there a trick to put that rubber cover back on or should I just remove it
Any advice would be greatly appreciated. Thanks in advance.
Old Sep 19, 2005 | 09:13 PM
Faizei's Avatar
Faizei
Anyone know how to put back the rubber cover on the bottom of the shifter?
Old Sep 19, 2005 | 09:24 PM
GZire's Avatar
GZire
I wouldn't recommend leaving the rubber boot off, it's there to keep materials out (dirt, mud, small rocks, etc.).
Feel around the bottom, you should feel a recessed section where the boot fits into. It's a matter of getting the interior edge of the rubber boot to fit in there. When I did mine thats what ultimately took me the longest time to put back.
Old Sep 20, 2005 | 10:44 AM
tcn75's Avatar
tcn75
go to any car repair shop and ask them for a lift. It's much easier when you have more space.
Old Sep 20, 2005 | 08:40 PM
Faizei's Avatar
Faizei
Thanks guys. Wanted to make sure that the rubber piece was suppose to go back on. Now, I will go borrow my friend's lift and put it back.
Old Sep 20, 2005 | 08:48 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Any noticeable vibration after the install? This is the only reason why I'm holding back is because I've read many issues with vibration in the past. Seems like they fixed this issue now which is why I'm looking into getting it again. Just wanted to get more feedback. Also, if you don't mind me asking...where did you order yours from? TIA.
Old Sep 21, 2005 | 06:05 PM
GZire's Avatar
GZire
I actually have less vibration than the OEM shifter. I haven't heard of problems associated with the Rogue shifters, just the others.
I bought mine straight from Rogue, but you can go to 350Evo.
Old Sep 21, 2005 | 06:09 PM
rgcarmack14's Avatar
rgcarmack14
I got mine from 350evo and I absolutely love it. I have NO noise, vibration, etc. whatsoever. In my opinion, it is the way the stock shifter should be. It is very precise when shifting. It is pretty tight at first but has broken in so well. I would not even consider going back to stock. If you are looking for something noise/rattle free, it is the one you want. I don't know what others have experienced but I have nothing negative to say about it.
Old Sep 21, 2005 | 07:02 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Thanks everyone...exactly what I wanted to hear . Guess I'll be getting one as well .
Old Sep 21, 2005 | 07:34 PM
Faizei's Avatar
Faizei
I got mine from 350evo. No noise and vibrations. It is actually much better than stock and you will fall in love with the shifting.
Old Dec 16, 2005 | 12:16 AM
ssk0771's Avatar
ssk0771
I had my Roque shifter for a while (about 8 months). Initially, I did not have any rattle but now, its starting to rattle.
I wonder whats causing it?
Old Dec 17, 2005 | 05:23 AM
gersteinp's Avatar
gersteinp
Just curious-- how difficult is the Rogue install? Did you guys keep the stock **** or change it out?
Old Dec 17, 2005 | 10:29 AM
ssk0771's Avatar
ssk0771
Its pretty easy. I think the toughest part is putting the rubber boot back on under the car where the shifter and tranny links
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
