Almost have the Quaife LSD install finished
Old Oct 19, 2005 | 02:42 PM
  #41
THX723's Avatar
THX723
Why complicate yourself by excluding G35 applications. Whether a particular combination exists or not for the Z, go by the 4 possible combinations (listed again below) and you'll know exactly what additional parts is needed for the Quaife LSD to work. It's that simple.
1. 5AT (3.3 FD ratio) + OPEN Differential
Quaife should be a direct drop in.
2. 5AT (3.3 FD ratio) + vLSD Differential
need open diff stub axles.
3. 6MT (3.5 FD ratio) + OPEN Differential
neeed 10mm spacer/bolts kit.
4. 6MT (3.5 FD ratio) + vLSD Differential
need both open diff stub axles and the 10mm spacer/bolts kit.
There are no other possible combinations.
Old Oct 19, 2005 | 02:52 PM
  #42
zillinois's Avatar
zillinois
Originally Posted by THX723
Why complicate yourself by excluding G35 applications. Whether a particular combination exists or not for the Z, go by the 4 possible combinations (listed above) and you'll know exactly what additional parts is needed for the Quaife LSD to work. It's that simple.
Technically it was Quaife who complicated things not me. I'll try a different way, has anyone successfully installed this on a VLSD yet?
Old Oct 19, 2005 | 06:10 PM
  #43
EnthuZ's Avatar
EnthuZ
zillinois, let me simplify. Quaife manufactures a fantastic LSD. Their R&D department couldn't turn on a light switch!
Old Oct 19, 2005 | 07:40 PM
  #44
dklau33's Avatar
dklau33
350Z_Al
Oct 29, 2020 07:44 PM
