Tranny being replaced, should I get the Nismo Flywheel?
Old Oct 13, 2005 | 10:42 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Originally Posted by Nano
http://performancenissanparts.com/ca...roducts_id=191
how much torque is the nismo clutch/flywheel combo good for?
how does the JWT clutch compare to the nismo clutch?
Both are good for about 400HP to the crank...
The differences between the JWT Clutch and NISMO clutch...
JWT Clutch weights about 2 lbs more then the NISMO clutch (JWt clutch weights about the weight of stock clutch)
JWT has more clamping force BUT has a sprung disc hub... So engaugement is smoother, but will not grab as quick since the springs have some give to the disc when it grabs...
NISMO has a little less clamping force (not much) but has a solid hub clutch disc so the clutch is more responsive...
NISMO has a softer pedal feel then the JWT...
Both work with factory flywheel / nismo / or jwt flywheels...
Lightest set up would be JWT flywheel w/ NISMO clutch...
Old Oct 15, 2005 | 09:09 AM
Jasud's Avatar
Jasud
Or....you could could go with the tilton set up(lightest)
Old Oct 15, 2005 | 11:58 AM
esfand's Avatar
esfand
DONT PAY THE DEALER A CENT. when they replaced my transmission the dealer told me i had to pay 4 a new clutch. i went to another dealer after the swap and the service manager told me that if the transmission is being replaced under waranty i shouldnt have paid 4 anything. i wish i knew that b4 i paid the other ****ers
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
