To those that installed there own cams
Old Jan 10, 2006 | 05:32 PM
  #61
EM-EFER's Avatar
EM-EFER
Originally Posted by knight_white99
That's why I'm driving there to have my cams installed next week (all the way from Phoenix!). I figure its worth the long drive and hotel expense to have some guys do this who have done a few and who know what they are doing.
Jason, see you Monday (btw, did you sell your brakes?).
After the first time I could probably do it without the manual by myself within 12 hours.. Installed and driving away.
Old Jan 10, 2006 | 07:20 PM
  #62
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
just so you know...
We got a phone call today about someone installing a plenum spacer...
Customer:
"You guys shipped cheap bolts, they wouldnt even meet the torque spec"
Us:
"Sir, its 17in-lbs not Foot Pounds..."
Customer:
"Oh, how do I get them out..."
Old Jan 10, 2006 | 07:27 PM
  #63
knight_white99's Avatar
knight_white99
Then I salute you, sir! You're certainly a better mechanic than I.
Old Jan 10, 2006 | 08:07 PM
  #64
jakesford's Avatar
jakesford
Originally Posted by Jason@Performance
just so you know...
Customer:
Us:
Customer:
LMAO... Oh well i was helping a friend replace his head gasket on his civic. B16 fully built with a 67mm turbo. I war installing the cams caps and torquing them down with 3 steps, and broke 3 bolts . Turns out that the cams had been removed several times before so the bolts had been torque down like 4 times before. So after a trip to the honda dealer for all new bolts @ nearly $1 each i finished it for him
Old Jan 11, 2006 | 05:36 AM
  #65
EM-EFER's Avatar
EM-EFER
Well tonight I finished installing all 4 cams, timed the cam gears, put on the timing chain,the chain tensioners and chipped away all the old RTV. Car will run for the first time tommorrow with my new setup.
I ll let you know if it was all worth it. If it doesnt snow on Sunday I will also get a dyno.
Old Jan 16, 2006 | 07:57 AM
  #66
FlorendoCruz's Avatar
FlorendoCruz
jus installed the nismo cams. Im having a rough idle. The rpm would drop close to stalling after i rev the motor? What can i do about this? Someone sed to go to the dealer and ask them to raise the idle but they might ask all these damn question on why i have rough idle. Can i raise the idle myslef? ANyone know how? Help would be appriciated. Thanks!
Old Jan 16, 2006 | 08:02 AM
  #67
Jason@Performance
Performance Nissan
http://performancenissanparts.com/ca...oducts_id=4849
Old Jan 16, 2006 | 08:11 AM
  #68
FlorendoCruz
thanks!
Old Jan 16, 2006 | 07:34 PM
  #69
FlorendoCruz
is that guaranteed to work?
Old Jan 16, 2006 | 08:08 PM
  #70
EM-EFER's Avatar
EM-EFER
What does it idle like?? My car is idling fine at almost 1000RPM
I cant wait till the salt is off the roads to test this *****.. also get it re-dynoed
Old Jan 16, 2006 | 08:19 PM
  #71
FlorendoCruz
its idles fine at neutral but after i rev it a little, my rpm pretty much drops and stalls. Takes the fun away from reving the car and hearing my nismo exhaust! This is killing me!...i hope u can help. Im going to try to go to nissan tommorow and ask if they can bump up my idle to mayb 950-1000. What do u suggest i do? Thanks in advance!
Old Jan 16, 2006 | 09:16 PM
  #72
JORGEOLIVEIRA's Avatar
JORGEOLIVEIRA
Builder/Framer
FlorendoCruz, lets try that first, before going to the Dealer
Old Jan 16, 2006 | 09:31 PM
  #73
EM-EFER's Avatar
EM-EFER
Hold on before you buy there... Iam going to make one and see what happens... I can make that kit for 10 bucks
Ill let you know tommorrow afternoon how I make out.. mine does drop to about 700RPM after I just checked.
Old Jan 16, 2006 | 09:41 PM
  #74
overZealous1's Avatar
overZealous1
i forgot about this mod when you pm'ed me. it does work, it is just making it so the ecu sees more air going through the maf and it enters into the intake behind the throttle plate. unfortuneately it won't work on the blow through greddy set up i have as it would of been drawing in unmetered air, so i went about it differently. but as luke figured out, you can do this really cheap.
Old Jan 16, 2006 | 09:43 PM
  #75
FlorendoCruz
hey i appriciate that Luke! Let me know as soon as possible. Thanks in advance!
Old Jan 16, 2006 | 09:48 PM
  #76
FlorendoCruz
JorgeOlievra, u think we can make this kit? hehe
Old Jan 17, 2006 | 05:02 AM
  #77
EM-EFER's Avatar
EM-EFER
Well I went to home depot with this diagram from Jim Wolf.. got everything to 15.76 with tax
http://www.jimwolftechnology.com/wol...BILITY_FIX.PDF
Put that bad boy in and idle is much better..
What you do is T the vacuum line going to the throttle body ..
Go from that T to the other T...
Now splice the line that going from the rear left valve cover that goes to the bottom of the intake pipe.
Take me 10 minutes.
Any questions PM me
Old Jan 17, 2006 | 05:26 AM
  #78
FlorendoCruz
Take me 10 minutes.
Any questions PM me
did it make a big difference? What does it do? Does it raise the idle higher or it jus stays at normal rpm and stabalizes?
Old Jan 17, 2006 | 05:31 AM
  #79
EM-EFER's Avatar
EM-EFER
It made a pretty big difference.. No more drop in RPM like before
What does it do
It creates more vacuum pressure so there is not as much fluctuation in RPM when letting off.
It raised the idle and also made it not drop like before..
You can do this yourself ... its really easy. Just print out that diagram and go into home depot to the fittings section and get the right sizes
Old Jan 17, 2006 | 05:53 AM
  #80
FlorendoCruz
yye but i cant print out the diagram for some apparent reason. Can u email be the actual diaghram and not the link. Mayb that'll work. I appriciate what ur doing and thanks alot.
