ECU Replacement Concerns
Old Jan 2, 2003 | 05:53 AM
jeffw's Avatar
jeffw
Default ECU Replacement Concerns
If we put a new ECU in our cars, will we lose variable valve timing (phase) and VDC/VTC (the cutting power bit, not the braking)?
I would guess the answer will be different depending on whether one goes with a piggy back or a complete replacement ECU...
Anyone with past experience replacing the ECU on technologically advanced cars? What features, if any, were lost?
Thanks,
Jeff
Old Jan 2, 2003 | 06:48 AM
Zaphod 350z's Avatar
Zaphod 350z
None. I would never buy an ECU that is going to remove features. As I stated in an earlier post, aftermarket ECU's are factory ECU's with a reprogrammed EPROM chip. The EPROM chip is what controls timing, a/f mixture, rev limiter, fuel delivery, top speed governer.
Old Jan 2, 2003 | 05:24 PM
2003z33's Avatar
2003z33
I agree. You shouldnt lose features. If anything youll gain a few horses and a ticket here and there
Old Jan 2, 2003 | 05:26 PM
2003z's Avatar
2003z
had the dinan programming on our old 2000 bmw 323ci, and it didn;t lose anything
Old Jan 2, 2003 | 05:29 PM
2003z33's Avatar
2003z33
Does anyone make an ecu upgrade for the Z's yet.
Old Jan 2, 2003 | 07:34 PM
n3985's Avatar
n3985
An upgraded ECU is only good for NA applications, if you plan on FI, then new engine management should be used. With that, they'll just completely remap every everything.
Old Jan 2, 2003 | 07:57 PM
jeffw's Avatar
jeffw
So would you lose variable valve timing and and VDC with a new engine management system?
Thanks,
Jeff
Old Jan 2, 2003 | 11:07 PM
phreezee's Avatar
phreezee
If a chip "removes" anything, it'll be the rev-limiter and top-speed governor.
Mines has a chip out... can't remember the website....
Old Jan 3, 2003 | 01:27 PM
TJZ's Avatar
TJZ
Mines makes the thing that removes the speed limiter and rev limiter but i wouldnt consider that an upgrade. So with that said, no.
sales@czp
Sep 23, 2019 03:30 PM
Mattg350z
Oct 2, 2015 06:51 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
