Why is the Nismo clutch sold as 2 seperate pieces?
Originally Posted by Chebosto
cuz you can usually just replace the clutch disc by itself than the pressure plate when u need to change it..
Originally Posted by Jason@Performance
because there are different discs that can be used with it to hold more hp / quicker engaugement...
Originally Posted by Anomaly460
When staying NA is the Nismo clutch disc the best to use? (is it the quickest/lightest setup)
Performance Nissan
Performance Nissan
there is also a 3 puck cerametallic clutch disc available from NISMO...
this will hold more HP then the copper organic blend clutch disc. but, you sacrifice easy clutch engaugement... but with more mass behind the flywheel and clutch, it does not stall out as quick as a tilton clutch with a cerametallic disc...
i wouldnt recomend this clutch disc unless running the car as a track / drag or non-daily driven car if NA..
Performance Nissan
Performance Nissan
NISMO FLYWHEEL is 23lbs.
JWT FLywheel is 14lbs
NISMO Pressure Plate & Disc is around 21lbs
JWT Pressure plate & disc is around 23lbs...
lightest fully streetable that anyone can drive no problem: NISMO Pressure Plate & Disc and JWT Flywheel. (We are offering a special on this set up this month till the end of the year 2005).
The lightest clutch and flywheel setup is the TILTON. It is 16lbs flywheel and clutch combined...
Yes, I recomend the NISMO Clutch w/ JWT Flywheel...
Ill be posting the special price Monday morning...
...Thanks though ill lookin for the special.
I used to have Nismo clutch and JWT flywheel setup, but now I'm back to stock.
I'm thinking about getting just Nismo clutch because the stock clutch grabs
so weak.
Would Nismo clutch work well with stock flywheel?
so weak.
Performance Nissan
Performance Nissan
ALong: I see no reason why the NISMO Clutch Disc will not work with the OEM Pressure plate... But dont expect too much of a performance difference... The hub is not sprung on the NISMO so engaugement will be a little quicker...
gsazabi: NISMO Clutch can be used with the stock flyweel no problem...
Do you know how much the stock pressure plate & disc weigh?
Performance Nissan
Performance Nissan
Sorry about the delay, had trouble gettin online yesturday.
NISMO Clutch & JWT Flywheel special.
https://my350z.com/forum/showthread.php?p=1907075
Performance Nissan
Performance Nissan
