Got My Car Finally Dyno'ed!
Old Dec 4, 2005 | 07:52 PM
mandm177's Avatar
mandm177
Default Got My Car Finally Dyno'ed!
Got my 05 6 spd enthusiast dyno'ed on saturday at USA Motorsports in Arlington, nice group of guys over there, anyways for the results.
Mods Include:
MD 1/2" Spacer
JWT Popcharger
Fisher Speed Intake Manifold Gasket Set w/TB coolant bypass
Xerd Longtube Headers w/Cat Deletes
Greddy EVO 2 Exhaust
still looking for more mods, and the only basic bolt ons from here are a crank pulley and a possible reflash (if anyone ever comes out with it for the 05's)
as usual, comments are welcome!
Old Dec 4, 2005 | 07:54 PM
ZON's Avatar
ZON
lookin' good!!
Old Dec 4, 2005 | 07:58 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Not to burst your bubble but I got my dyno at 254 bone stock. I thought you would get higher numbers with all those mods....I since then have the Motordyne spacer 1/16, Crawford cats, Invidia G200 exhaust and a Injen Intake. I wonder if I lost any power at all but I have not since then Dyno'd her
Here is a copy of the Dyno
http://img.photobucket.com/albums/v2...o-70kmiles.jpg
Now keep in mind I got a wheels dyno pack so that may be diff then what you got
Old Dec 4, 2005 | 08:19 PM
mandm177's Avatar
mandm177
i THINK, dont quote me on this, that dynopak's generally read higher because they replace the wheels and dont take into the effect how much the wheels way...
what was really stupid on my part, was the fact that i never got a baseline dyno so that i could see the change between the two. these numbers are now my baseline, and all my mods that i do from here on out, im going to have to compare to this, not my non-existant stock numbers...
Old Dec 4, 2005 | 08:22 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
I think you may be right. The mass of the wheels would affect the dyno readings or am I wrong. I now need to dyno her and see what if any increase I may have.
Old Dec 4, 2005 | 08:42 PM
mandm177's Avatar
mandm177
yep, thats the most important thing anyways. to see if your parts have made any measurable difference. which i have no idea if mine have, but oh well, might as well start now...
Old Dec 5, 2005 | 12:12 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Did you get A/F? You may benefit greatly from tuning your A/F, your hp #'s are a little low, your TQ is def low especially for having long-tubes. BTW is this SAE/STD or no correction?
Old Dec 5, 2005 | 12:24 PM
mandm177's Avatar
mandm177
i forgot to ask for the a/f ratio, as it would have been a great benefit, but seeing how i have no piggy back or reflash, how would i tune it?
i can find out, but i dont think that these numbers are corrected...would there be much of a difference if they were or not? i have a friend who got his car dyno'ed also, so i can find the temps, humidity, and altitude for the correction. is there a program that will convert the numbers for me?
Old Dec 5, 2005 | 12:47 PM
RNL323's Avatar
RNL323
Mod My Ride
254 stock... Seems HIGH.
I Dyno'd on Saturday and hit 250 with Jwt, 1/4 spacer, strup headers, and unichip....
My AF was 12.8 which I was advised to be the best for my set-up
Old Dec 5, 2005 | 01:00 PM
Z350Lover's Avatar
Z350Lover
dynopack normally dynos the car with higher numbers... and also we cannot just compare any dyno numbers from different dyno machines (even if they are the same type of machine), its like comparing prices on apples of different types...
Nice torque curve though!!! you can definitely feel the sudden pull from 4000rpm to 5000rpm!!!
cheers,
richie
Old Dec 5, 2005 | 01:38 PM
sisco534's Avatar
sisco534
You are right they dyno a little higher MAKE sure you go back to the same place...always to to dyno on the same dyno to get accurate results.
Old Dec 5, 2005 | 01:54 PM
KingOfV6's Avatar
KingOfV6
i dynoed this weekend in at Velocity motorsports in dallas tx, and i got 234 hp and 220 tq, stock 05 6 speed enthusiast, with greddy evo 2 and exhaust, and JWT Popcharger.
Old Dec 5, 2005 | 01:57 PM
Alberto's Avatar
Alberto
Cranky FI Owner
An SAE correction will read lower than a STD correction, and if your ocnditions were decent, then your actual could be high compared to your SAE...it would be on the top right corner of your dyno printout, I just cant see what the correction is in the pic, it will say Correction: SAE or none or STD....
Old Dec 5, 2005 | 11:19 PM
imseksy's Avatar
imseksy
what does the Z dyno at stock? the 300hp version. does anyone know?
Old Dec 6, 2005 | 12:03 AM
05 NISMO's Avatar
05 NISMO
got pretty much the same... look at my sig.
Old Dec 6, 2005 | 04:47 AM
PoWeRtRiP's Avatar
PoWeRtRiP
keep in mind you cannot compare 2 different dynoes to one another. each type will read different depending on the model, user load settings, altitude, weather, etc. anyone who tells you that the 300hp will dyno xxxhp is wrong. a more appropriate answer would be it can be anywhere between xxx-xxx on a dynojet, but xxx-xxx on a dynapack, or xxx-xxx on a mustang. a dyno is not a good tool for measuring true hp, it is a TUNING AID.
Old Dec 6, 2005 | 05:27 AM
dynamic6er's Avatar
dynamic6er
Nice! Our flash is available for the '05's. Did you get an A/F readout? My guess is you could gain somemore power since most likely your starting to get on the leaner side of things.
Link to flash:
http://www.alteredatmosphere.com/350z/350z_13.asp
Old Dec 6, 2005 | 05:33 AM
Gman2004's Avatar
Gman2004
Nice, but I would recommend you get the UTEC and get a custom tune. You could net 10-15whp more.
Old Dec 6, 2005 | 10:11 AM
RNL323's Avatar
RNL323
Mod My Ride
Or Unichip...
I gained +25HP @ 5500rpms. Most of mid-range was around +15hp. Top end was only 243hp because of stock exhaust.
Boooo Hisss... Stock exhaust.. Booo!
Old Dec 6, 2005 | 10:43 AM
mandm177's Avatar
mandm177
interesting...there is a unichip tuner here in north texas at forced induction systems, but its been a while since ive heard anything from them. i wonder if they are still in business. i would like the AAM reflahs, but id want to do a dyno session rather than just send in my ecu to get tuned. besides, i promised myself no more spending money on the card until i get out of debt! haha
user 62082028
Southern California
Jul 28, 2017 11:47 AM
gc350z03
Oct 28, 2016 05:00 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
OperatorAF
Sep 13, 2015 11:36 AM
