What do I need to know before fixing NISMO cams?
Old Dec 9, 2005 | 11:41 AM
Bahraini350Z's Avatar
Bahraini350Z
Default What do I need to know before fixing NISMO cams?
I am recieving my R-tune cams in a couple of days and I want to do it the right and safest way
I will be doing it at my friends workshop wich he already is familiar with such a job (given that he changed some cams for Maximas)!
My car is at the agent now and I requested them to raise the idle to 850 as I read somewhere in this forum.
I know it says NO ECU adjustment is required, but I still feel that things might go wrong. Any help or feedback is most welcomed
Thanks
Old Dec 9, 2005 | 01:12 PM
overZealous1's Avatar
overZealous1
https://my350z.com/forum/engine-and-drivetrain/151876-to-those-that-installed-there-own-cams.html
most the info you need is here. get a shop manual too.
Old Dec 9, 2005 | 01:20 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
You may consider getting the ecu re-flashed after the install to maximize the timing and air-fuel. I had this done on my car and it helped when I had the cams in at the time.
Old Dec 9, 2005 | 07:54 PM
Bahraini350Z
Thanks guys. And I already have the manual ready with the desired pages printed
Old Dec 10, 2005 | 09:44 AM
287HP's Avatar
287HP
Raise Idle to 850, advance timing 2 degrees via consult II. Car will run fine, but a/f will be a little lean without a reflash or piggyback.
Old Dec 11, 2005 | 01:02 AM
Bahraini350Z
I did raise the idle to 850 at the dealer yesterday. But, can I advance the timing there as well?? (not sure what a consult II is )
Old Dec 11, 2005 | 06:22 AM
Dubai's Avatar
Dubai
Nissan has the consult II and I beleive they can advance the timing for you.
I understand you're living overseas and you wont be able to get a reflash. I highly recommend getting a piggyack such as the UTEC or EU, you'll be running lean as metioned above.
Old Dec 11, 2005 | 01:11 PM
Bahraini350Z
Still a reflash with shipping the ecu is cheeper
Is 2 degrees of timing advancement the magic figure OR it differs from a car to another?
Old Dec 11, 2005 | 05:15 PM
Z PHAT Z's Avatar
Z PHAT Z
Flash is cheaper in a short term. What if the first time you flashed the ECU and it doesn't work well? Then you have to mail it out and re-flash it. The flash is $595 + shipping and time consuming. Also flash can't let you tune your car to the finest. with the UTEC, sure it cost more but it's better for your car. With the Utec, you can use it for NA tuning or if you go FI; you still can use it.
Uriyo_
Sep 8, 2021 08:46 AM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
