How much WHP...
Old Jan 2, 2006 | 09:19 PM
adamloan's Avatar
adamloan
Default How much WHP...
.. will i get. from an HKS high power exhaust, an injen cold air intake, DC sports headers, a random tech high flow, skunk 2 plentium spacer, and is there any other products that are better than these and what other products are there that will increase my HP without turbo-charging or super-charging? what is the max HP i can get my car up to also without turbo or super charging? lastly, will a fly wheel and new clutch add HP to my car.. and if so.. which ones? money is not a concern (i don't want to put cams on either) this is a stock 2004 350z. thanks for your help!
Old Jan 2, 2006 | 10:14 PM
ZON's Avatar
ZON
Cams
Old Jan 2, 2006 | 10:17 PM
adamloan's Avatar
adamloan
Default How Much Whp
Will That Give Me Total
Old Jan 2, 2006 | 10:19 PM
eckocomplexg's Avatar
eckocomplexg
Search is your friend... Use it...
I would recommend looking at what others have done and what's worked for them. Depends a lot on your taste in sound of exhaust and all that.. i say do a lot of reading before you buy anything to get what you desire otherwise you're gonna throw your money away... search and read A LOT
Old Jan 2, 2006 | 10:26 PM
Mike Wazowski's Avatar
Mike Wazowski
(insert smart azz remark here)
Old Jan 3, 2006 | 12:10 AM
thawk408's Avatar
thawk408
If money is not a concern and you don't want to go FI (i know you said no cams, but sorry) I would do the AEBS 4.3 stroker kit with 11.5:1 CR, HUGE cams, built heads with oversized valves, all supporting bolt-ons, and motec. This combination will give you huge NA gains. I know you won't do this, but it is just wishful thinking.
Old Jan 3, 2006 | 12:52 AM
JETPILOT's Avatar
JETPILOT
And a turbo Z car pushing only 7PSI will still put the hurt on that NA setup for about half the cost. Join the FI crowd. Move to the dark side. It's the only way.
Respect
JET
Old Jan 3, 2006 | 01:08 AM
thawk408's Avatar
thawk408
Respect
JET
I know FI will own NA in pure power, but there is just something about an NA motor that I like. I like FI also, don't get me wrong, but NA is more my style. But who knows, my desires could change.
Old Jan 3, 2006 | 01:25 AM
Fairlady_z33's Avatar
Fairlady_z33
What is it that you like about NA
Old Jan 3, 2006 | 01:31 AM
JETPILOT's Avatar
JETPILOT
Unless your rich... your not becasue you drive a Z and want to go fast...... turbo's are the only way to go.
For $5000 there is no discussion of NA/FI. 380 RWHP can't be done NA for even double that.
This is an academic discussion to have over a beer at the bar. When you have to pony up to the table and flip the bill FI is the only way to do it.
I like the fact for $5000 I can have 380 rwhp.
Respect
JET
Old Jan 3, 2006 | 01:34 AM
adamloan's Avatar
adamloan
Default Na/fi
Want To Keep My Waranty That Is Why I Want To Stay Na, Also Is Thehks Hi Power The Best System On The Market.same Question With Dcsports Headers
Old Jan 3, 2006 | 01:39 AM
adamloan's Avatar
adamloan
Default F*** The Waranty
What Is A Safe Fi System I Can Use That Will Not Blow My Motor And What Can I Do To The Motor To Make it More Stable Using Fi.this Is My Only Car And Do Not Want It In The Shop Every Two Months Getting Fixed for a week at a time I WILL COME TO THE DARK SIDE will 16k do all things i need
Old Jan 3, 2006 | 01:47 AM
JETPILOT's Avatar
JETPILOT
Well turbo kits don't blow motors. Bad tuning does. For a stock car the Turbonetics kit is awesome, and works well. 360-380 rwhp out of the box. You will likely need a new clutch, and wider tires. 275 minimum in the rear. 295 being a better choice. Other than a few guages you are good to go. You will be overwhelmingly likely to never have a problem, and run WOT all day long. All the NA mods your looking to do to your motor will void the warranty anyway. Sooooo go big time.
Respect
JET
Old Jan 3, 2006 | 04:47 AM
What mods do you have to date?
Old Jan 3, 2006 | 05:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Just because you put the "best" mods known mods/brands on doesnt mean you'll get the best gains. The secret is finding out what mods work best together. With that set up you could be 255whp or be around stock power levels, it depends a lot on your ECU and how your car handles the mods. I suggest you do some research and try to learn-there is plenty of good info on this board and there have been many "what is the best XXXX threads"....
Old Jan 3, 2006 | 06:49 AM
PoWeRtRiP's Avatar
PoWeRtRiP
id say 450 whp with those mods. have the dyno operator adjust the load and correction settings and youre a happy camper. without a baseline you have no grounds to even compare the gains u get with those mods. a dyno is not a bragging tool, its a tuning tool.
Old Jan 3, 2006 | 06:53 AM
thawk408's Avatar
thawk408
The sound. Lighter then being turboed. Not having to add a power helper.
Old Jan 3, 2006 | 08:20 AM
ZON's Avatar
ZON
Where in California are you, Adam? For 16K I can definately hook you up with an awesome APS TT install and you will own an absolute monster, 450 whp at least safely on a stock block. It will be reliable and you will not blow your motor because it will have an very safe tune from a pro Z car shop that has done at least 25 APS TT installs and tunes. You could have that for less than 16K and spend the rest on other goodies like rims and tires or suspension or whatever. Is your Z a 6 speed manuel?
Old Jan 3, 2006 | 09:15 AM
D350Z10's Avatar
D350Z10
The perfect goal for na parts is 300whp with the utec now out it is possible... but you have to get the parts with the best gains...
TURBO XS UTEC
Jim wolf Cams
Crawford Headers
Aps or Crawford Plenum
Apexi 3in Exhaust
Helix or Kinetix Test pipes
Injen CAI
UR PULLEY KIT
Grounding kit
Old Jan 3, 2006 | 11:34 AM
thawk408's Avatar
thawk408
Respect
JET
How do you know how much money I have? Right now I would rather try it NA. FI would get me there, but everyone and their brother has done FI. I have not seen many NA build-ups. What kit are you talking about doing for $5k. Does this include clutch/flywheel, gauges, fuel managment, and possibly a boost controler. Also, 380rwhp is near the limits of the stock fuel system.
