stock flywheel with JWT clutch?
Old Jan 29, 2006 | 01:51 PM
tig488's Avatar
tig488
Default stock flywheel with JWT clutch?
will the JWT clutch and plate work with the stock flywheel?
Old Jan 29, 2006 | 03:04 PM
narkotic's Avatar
narkotic
yes
Old Jan 29, 2006 | 03:35 PM
J3rzeyFlip's Avatar
J3rzeyFlip
why would u do that? If i was u, id buy the aftermarket flywheel, either Nismo or JWT and combine that with the JWT or Nismo clutch. Ull save money in install. Eventually, ur going to think of replacing the flywheel anways and might as well do it in 1 process. If u have $ for the flywheel yet, i suggest u save up for money. Jus my opnion.
by the way, alot of poeple are very satisfied with JWT flywheel and Nismo clutch. Id look into that and do some research before u buy it! Good luck!
Old Jan 29, 2006 | 04:12 PM
SpeedRcr's Avatar
SpeedRcr
because he broke some bolts while doing his own install...
Old Jan 29, 2006 | 05:18 PM
tig488's Avatar
tig488
what he said. well kinda, i didnt brake bolts, the threads in the aluminum JWT flywheel shredded. this is my daily driver right now, and i need it back running asap. so i cant wait on a replacement. all i need is the stronger clamping force, not the faster rev.
Old Jan 29, 2006 | 07:42 PM
zzzya's Avatar
zzzya
I read your other post as well, but I would suggest just using the stock flywheel for now. Self installs are always easier the second time around if you truly want to go with the lighter flywheel. Either that, or I would order a new one and rent a car for a few days until you had the new one installed. I know it sucks, but I wouldn't take a chance and possibly damage the crank shaft or main bearings.
Old Jan 29, 2006 | 07:48 PM
tig488's Avatar
tig488
im thinking about using some helicoils for the stripped threads.
Old Jan 30, 2006 | 03:21 AM
SpeedRcr's Avatar
SpeedRcr
hey tig go get some level 10 bolts for your reassembly...the stock bolts are level 8...just extra piece of mind
EnjukuRacing
Sep 30, 2015 06:55 AM
