The Z is shuting off for no reason, HELP!
Old Feb 14, 2006 | 05:03 PM
manny007's Avatar
manny007
Default The Z is shuting off for no reason, HELP!
When I'm around 55- 70mph or so and shift into neutral and attempt to brake
to slow down the car sometimes the car shuts off completely.
I repeated this routine several time today and the car shut off on me about 5 out of maybe 10 tries.
Recently I converted my Injen Cold Air Intake to a short air intake and a new tranny about a month ago.
Tomorrow I will go back to a cold air intake to see if that is the problem, In the mean time does any one have any input on this matter?
Thanks!
Old Feb 14, 2006 | 05:36 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Do your dash lights lightup? (SES, Check engine)
Old Feb 14, 2006 | 05:41 PM
manny007's Avatar
manny007
Yes all of the lights lite up.
Weird?
BTW- Just sent you a PM
Old Feb 14, 2006 | 05:47 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You might have a vaccum leak somewhere. I had this happen when I put the SSV on. Had a small leak. Under throttle it's was fine but when you let off it shut off. Air was getting in and messing with the sensors. Tighten up all your intake bolts an dmake sure there's no leaks. I'm betting there's a small one somewhere
Old Feb 14, 2006 | 05:52 PM
MadBoost's Avatar
MadBoost
Could have something to do with your intake and the placement of the filter in relation to the maf if it didn't do it before. My old EVO 8 did that and I know the Mazdaspeed Protege guys have the same issue from the factory.
Old Feb 14, 2006 | 06:20 PM
rotaryrocket7's Avatar
rotaryrocket7
There's been some other people who complained about the engine stalling after letting the car idle while at speed. I believe that all had the popcharger. I also read somewhere on here that there was a fix, which was putting a piece of tape on the bottom of the filter (1 piece, vertical position from the bottom center). I guess there was some reversion of air do to low pressure blah blah blah... Give it a shot, no harm done if it doesn't work. Try searching to find the thread. I think it was titled something like car shuts off at 120 MPH
Old Feb 14, 2006 | 06:41 PM
DavesZ#3's Avatar
DavesZ#3
I recall there being several threads on the stalling problem with popchargers. Usually occurred after a prolonged high speed run when they let off the gas and started to coast in neutral. Engine would die mysteriously.
Old Feb 14, 2006 | 09:00 PM
manny007's Avatar
manny007
Exactly my problem. Tomorrow I will go back to a cold air intake and see if the problem disapears.
If not I will take everyone's advice and continue to attempt to locate the problem.
Thanks for everyone's reply, please do continue to chime in and give your thoughts on this problem.
I will post up if converting back to a CAI solved the problem or not; will see
Old Feb 14, 2006 | 09:04 PM
manny007's Avatar
manny007
Tom I never would have guessed you would have owned a EVO 8
Old Feb 14, 2006 | 09:07 PM
manny007's Avatar
manny007
Hopefully not, all I did was take off the hose( sorry can't think of the name right now) that you orderd for your V-SC from Injen and relocate the filter.
Old Feb 15, 2006 | 07:24 AM
MadBoost's Avatar
MadBoost
Briefly, hated the quality of the lancer interior. LOL!!
Old Feb 15, 2006 | 07:26 AM
Juno's Avatar
Juno
Me either...just can't picture it! LOL
Old Feb 15, 2006 | 08:22 AM
manny007's Avatar
manny007
I think at one point or another most Z33 owners did think about buying a EVO, STI or a RX-8
Old Feb 15, 2006 | 08:24 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
STI yes, never the RX-8 though
Old Feb 15, 2006 | 09:04 AM
manny007's Avatar
manny007
I almost bought an STI, but bottom line, the looks were not impressive.
As for the EVO, definitly not impressed, felt like a test drove a Toyota Trecel with a beefy engine.
Old Feb 15, 2006 | 11:45 AM
Juno's Avatar
Juno
Not this one! LOL Unfortunately, I'm married to someone who traded a Z33 for an STi. But, that situation has been taken care of.
Old Feb 15, 2006 | 11:51 AM
350z bra's Avatar
350z bra
check ur intake make sure its tight!
Pleask
Dec 21, 2021 03:17 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
carid
Misc.
Sep 10, 2015 06:16 AM
