disappointed dyno numbers.....
268 hps/257 torque. i lost 3 hps since my plenum and intake but i gained 14 torque (270.5/243.4). a/f was 16.5 is that the culprit? i did a reflash when i installed pulley, hfc, and y pipe. since then i took off the y pipe and got hks exhaust. if i reflash the ecu again and run 13:1 ratio would i gain about 20 hps that i should with the mods?
Did you do a dyno pull for AFRs and determine if an ecu flash was needed before you sent yours in?
There are many other factoring in on your dynos:
Correction factor
humidity
temp
etc.
A 3 hp loss could just be variances in the dyno itself and not indicating a true loss. I would be happy with the tq gains you are seeing. Personally, I think your numbers are high for the parts you are running so be happy with that.
Was your AF really 16.5:1 at WOT? If so..you engine is not going to last very long.
I assume that is a typo. The numbers are excellent for your mods, and the fact you gained 14ft/lbs is impressive. Oftentimes NA mods and tuning will generate more meaningiful improvements in the midrange, and smaller gains up top.
What kind of dyno was this? Can you post your dyno chart?
What was the old and new correction? Dyno type? I ran my car as lean as 15.3:1 a/f(at worst) avg 14:1 and leaner for months before biting the bullet and doing a flash. Gained 9whp/12 ft/lbs with it and midrange. BTW Id take all that TQ and lose 2whp peak anyday....
no scanner
i'll try to take a clear pic
the a/f ratio reading of 16.5 is from like 2k rpms. then it dips down to like a 13 and climbs back up to 15.6ish. im going to reflash the ecu again this week and do a dynojet dyno. reason numbers are high is because they were on a dynopak
if the sensor was at the tail pipe then its not an accurate a/f ratio. im not sure how much it could be off, but it may not be as bad as you think.
i would encourage you to get it tuned and have the a/f read in the actual exhaust stream via one of your o2 sensor bungs.
I think since the A/F was measured at the tailpipe, realistically the A/F is not that high. I think it was DaveZ that told me that it would come out higher at that end, something like a point higher.
just got back from technosquare. i had a slight pinging and fixed it. af is now 13:1 and car pulls hard all the way til 7k. redynoing it this sunday. i'll figure out a way to scan it =D
seagrasser
Oct 11, 2015 03:27 PM
