JWT Cams and Nismo VTC???
Old Mar 2, 2006 | 08:28 AM
done12many2's Avatar
done12many2
Exclamation JWT Cams and Nismo VTC???
I will be installing JWT cams during my build up this month and am trying to get more information regarding whether or not the Nismo VTC will aid any in the overall tuning.
I understand that the JWT cams are not nearly as aggressive as the high end Nismo racing cams or Tomei cams, but will the VTC help at all with overall tuning? I will be buying a UTEC for tuning regardless of whether or not I end up buying the VTC.
My internal setup is Wiseco 11.0 to 1 pistons, Eagle H-beam rods, JWT cams, and the JWT spring and shim set. If I will lose a bit of midrange with the JWT cams I would rather use the VTC controller, but if the majority of the forum members feel like this is a complete waste of money, I will just leave it out of the build up.
Please give me you thoughts on this!
Old Mar 2, 2006 | 08:49 AM
jcarp's Avatar
jcarp
For Anybody Looking To Put Test Pipes On. The Parts Department Told Me That My Warranty Would Not Be Voided And I Will Still Have My Powertrain Warranty Just Not My Exhaust Warranty. My Motor Died On Me Friday With 2400 Miles And 1 Month Old And They Are Telling Me That I Have To Buy A New Motor Even Though It Was The Crank Or Tiiming Chain That Messed Up. Abunch Of Bs. Nissan Sucks
Old Mar 2, 2006 | 09:52 AM
rednezz's Avatar
rednezz
Depends on what you want. The VTC pullies are more for low end to mid range Torque with aggressive cams. Up top your stock pullies will work fine.
Old Mar 2, 2006 | 10:16 AM
done12many2
Did you just post in the wrong thread?
Old Mar 2, 2006 | 10:19 AM
done12many2
My understanding is that the cam are going to do what they do at the higher RPMs, but that the VTC allows you to add more to the midrange and low end.
With that said, do I lose a noticeable amount with the JWT cams in the low to mid end? Would the amount lost, justify the purchase of the VTC?
Old Mar 2, 2006 | 10:21 AM
EM-EFER's Avatar
EM-EFER
Adam from Z1 would be a good person to ask
Old Mar 2, 2006 | 11:58 AM
rednezz's Avatar
rednezz
I don't have JWT cams but from the couple of dynos I have seen compared to my stock baseline dyno you don't lose that much from the low rpms to around 3500 rpm. After that they take off. If the angle on the VTC pullies are adjusted correctly I am sure you can gain a little more power in the mid to low ranges. The problem is I don't know what angles you need for the JWT cams. The VTC pullies were made for more aggressive cams than the JWT. In my opinion they would not be worth the expense for the JWT cams. You would probably spend more money experimenting with the angles and then not gain a whole bunch a power down low.
Old Mar 2, 2006 | 12:40 PM
ACEMAN's Avatar
ACEMAN
Master
Here you go, Richie has been doing alot with his engine. Good read
https://my350z.com/forum/showthread....=cheers+Richie
Later
Aceman
nanotech
Oct 2, 2015 05:02 AM
