UTEC USB Support?
Old Mar 16, 2006 | 04:24 PM
drumma022's Avatar
drumma022
Default UTEC USB Support?
Has anyone been able to get the UTEC working while connecting to is using the a USB cable only? I know you can use the Serial adapter, however Jermaine said that you can connect by using only the USB ports on the unit.
Old Mar 16, 2006 | 04:29 PM
one350zfan's Avatar
one350zfan
^^Same problem... at this very moment!
Old Mar 16, 2006 | 04:31 PM
Ztampa's Avatar
Ztampa
Subscribing.
I've been trying all night to get mine to connect via USB. I installed the driver and tried every possible com port / emulation combination. No luck.
Old Mar 16, 2006 | 06:14 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It works. You have to goto your device manager, and find out which COM port the UTEC is connected to. Then it's just a matter of setting up a connection in Hyperterminal, and selecting the appropriate com port.
And of course, make sure you have downloaded the USB driver from TXS's website.
Old Mar 16, 2006 | 06:42 PM
wong hun xun's Avatar
wong hun xun
works for me
Old Mar 16, 2006 | 06:52 PM
fergraz's Avatar
fergraz
1. You need to install the USB drivers in your Laptop.This drivers are a emulator of a serial port.
2. Open the HyperTerminal ( I assume that you configured the HyperTerminal first with the com port emulated by your USB drivers. You need to do this with the car switch on and with the USB cable connected).
3. Turn on the car switch.
4. Press Esc to refresh your screen. This is because initially you will give a blank screen due to the delay of the computer to recognize the USB port.
Old Mar 18, 2006 | 08:19 AM
Ztampa's Avatar
Ztampa
I'm connected. Apparently, when I originally hooked it up, Windows found the wrong USB driver and installed it. I hadn't unziped the driver, so the wizard probably didn't see it. I just had to go in to "add hardware" and use the CD.
Thank for the help.
Old Mar 18, 2006 | 01:58 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
mine has been running since day 1 using only the USB
download the drivers from turboxs.com - and then configure your com port accordingly in hyperterminal
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
