MAX POWER STD GEARBOX and DIFF WILL HANDLE ????
Old Apr 5, 2006 | 01:51 AM
D1 350Z's Avatar
D1 350Z
Default MAX POWER STD GEARBOX and DIFF WILL HANDLE ????
Hi There,
Interested to know what power the stock 6speed manual gearbox and diff will hold before BANG.....
My car is due out of the workshop next week and we are expecting 700-750 RWHP.....
The main focus is drag racing at this stage so slicks will be used also.
Any info will be greatly appreciated as there is no one in OZ making this sought of power.
Thanks for your input
Old Apr 5, 2006 | 02:05 AM
BamBam's Avatar
BamBam
Well, I am sure you will get more educated responses, but here is my understanding.
I have not heard of anyone mentioning having to change the gearbox because of too much power. A number of people have mentioned doing it to create a better power delivery mechanism, but not because of power loads.
As for the diff, I think most people in that power range have changed diffs and axles.
I am in process of a similar power build and we have not looked into any gearbox changes, only replacing the axles and diff.
Good luck and let us know how it goes..
--B
Old Apr 5, 2006 | 03:29 AM
D1 350Z's Avatar
D1 350Z
Thanks very much for the info its greatly appreciated.
So if you dont mind me asking what diff and axle setup are you planning to use?
Thanks Again mate
Old Apr 5, 2006 | 12:45 PM
BamBam's Avatar
BamBam
Yea, I have the ATS carbon clutch style LSD and DriveShaftShop's Level5 Axle.
These should hold you easy at your planed level.
Old Apr 6, 2006 | 12:21 AM
D1 350Z's Avatar
D1 350Z
Thanks BAMBAM,
I just checked out there site, will have to give them a call 2moro. Im keen to try these stage 5 axles.
What are they worth?
They only listed stage 2 for $795 on there site.
Cheers
Anthony
Old Apr 6, 2006 | 01:28 PM
ZRD350Z's Avatar
ZRD350Z
Contact Sharif @ forgedinternals.com, he lists the stage 5's for $1549.00.
Old Apr 6, 2006 | 09:04 PM
BamBam's Avatar
BamBam
Anthony,
Yes the Level 5 axles are roughly around $1300 - 1500. I am not sure, but that sounds about right. DriveshaftShop just finished making some, so they should have some in stock if you are interested in picking them up now.
AAM can arrange drop shipment to anywhere and can also give you any info you might be interested in regarding concerns about your power level.
Regards,
--B
Old Apr 7, 2006 | 12:44 PM
dklau33's Avatar
dklau33
With those power levels and a goal of drag racing I'm sure you'll want to change out your clutch disc to one that acommodates the increased torque.
Old Apr 7, 2006 | 12:58 PM
Juztin's Avatar
Juztin
perf nissan was running the nismo lsd w/ upgraded half shafts on their 8 second 1/4m Z. Although I remember it being an auto, but not sure if they swapped out the tranny with something else... But I've never heard of issues with the diff/tranny before either.
Old Apr 7, 2006 | 04:47 PM
D1 350Z's Avatar
D1 350Z
Thanks for that info guys, yeah i have a twin plate clutch already built for the Z.
I have also contacted sharif @ forgedinternals and ill proceed with the order from him.
So what auto transmissions do you guys run over there? specs, brand e.t.c.
Thanks again
Anthony
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
