Mileage improvement mods
Old May 14, 2006 | 11:55 PM
krismax's Avatar
krismax
lighter car will really help alot but lighter pullies and flywheel will help with MPG too.
Old May 15, 2006 | 12:17 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by undrgnd
I've seen a lot of threads regarding going lean after breathing mods. Why is it that the ECU doesn't compensate? Isn't this a closed system with the O2 sensors and MAF? If it's not maintaing A/F, what exactly is it doing, anyone?
It most likely does compensate, only it may take a while. The main issue with stock ECU is it is unpredictable.
Old May 15, 2006 | 02:32 AM
Zincognito's Avatar
Zincognito
lol.....to me good gas mileage + teh Z = no such thing. thats just my driving when im but its also the reason it stays in the garage Mon - Fri. i need to slow down..hehehe
Old May 15, 2006 | 04:51 AM
sp1kez's Avatar
sp1kez
I don't know how you guys get ****ty gas mileage. I get 27 mpg city/hwy. The lowest I ever got was 23 mpg and that was trying.
Old May 15, 2006 | 02:02 PM
undrgnd's Avatar
undrgnd
Man, I have got some good ideas here. I still need to drop some more weight (spare and jack) and install the iridium plugs and HKS Twin Power DLI II. If I can hit 30 with all that, I may forego that Civic I was looking at. What about fuel additives? Has anyone tried anything that could improve the mpg?
Old May 15, 2006 | 07:48 PM
Zincognito's Avatar
Zincognito
i was reading the manual (imagine that) the other day and it says NOT to add fuel additives..........but i could just be a newb??
Old May 15, 2006 | 08:36 PM
CAN0802's Avatar
CAN0802
Originally Posted by gatti-man
only if you drive heavy freeway with no traffic. once again all your efforts are going to be negated by the cost of the mods your trying to do in the first place. Kindof seems silly to me. Getting the 300hp and ~ 22 mpg is great efficiency when you factor in ac and the high gearing we have. You want to save mpg? drop your gear ratio, but then you have a slow car imo.
If you drive heavy freeway traffic, the Z is the wrong car. If you don't have to drive in heavy traffic, my methods will work. Generally, if traffic is that bad for you, anything less than a hybrid will be bad.
Old Oct 15, 2006 | 03:51 PM
undrgnd's Avatar
undrgnd
Default Update!
After 5 months of driving, and a handful of mods, I need to update the results of my quest for better gas mileage.
I never installed the DLI-II - long story- so I can't say what effect it has on mpg, although I would bet it's positive. I was also not very scientific in that I did several of the changes at once, and can't say which mod did what.
After installing iridium plugs, Crawford headers, MREV2, APS plenum, and AAM HFCs to what I already had when I started this thread (K&N panel filter, JIC Y-pipe and Amuse R1000 titan), overall mileage went from mid 23 to almost 30. Intermittently mileage does vary, sometimes as low as 25, but I think it has something to do with my right foot.
In summation, the biggest 'positive' impact on fuel mileage is as shown below, in order.
1. Conservative driving and higher tire pressure,
2. Acetone mixed with the fuel, ~3oz/10gal gas,
3. HFCs, MREV2, APS plenum
4. K&N panel filter, iridium plugs and synthetic fluids (started off with Mobil1, but RP actually improved over that),
5. JIC Y-pipe, Amuse exhaust
6. Crawford headers
Some of the ratings were close, and the effects may be reversed if I retune for performance. Also, I feel the motor is still breaking in (~4600mi now). I understand some of the results, but not all of it, and I have done a lot of reading HERE.
Old Oct 15, 2006 | 03:57 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Because a civic doesn't look like a Z?
You bought a $30,000 car and are now worried about gas mileage?
Old Oct 15, 2006 | 04:32 PM
undrgnd's Avatar
undrgnd
^^^ Not sure I said I was worried about anything. You missed the point. ...and it cost a lot more than $30K.
Old Oct 15, 2006 | 06:43 PM
bleunetizen's Avatar
bleunetizen
run thinner engine oil
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Stevo Z
Oct 3, 2015 09:14 PM
Mattg350z
Oct 2, 2015 06:51 AM
Tochigi_236
Sep 27, 2015 03:40 PM
