sun auto hyper force install
Old May 13, 2006 | 11:31 AM
islandsnow's Avatar
islandsnow
Default sun auto hyper force install
Just finished installing the sun auto's hyperforce system. It was an easy install, unplug the spark plug connector, plug this into the new hyperforce harness and plug in the hyper force connector to the spark plug. There is one plug to the hyper force unit itself and one small wire to the positive lead of the battery. After starting the car the unit pulses a blue led looks pretty cool. So far it could be the combination of my undoing the neg lead on the battery, (reset the ecu) but i feel more power, feels more torquey. The obvious things from the install are the smoother idle and revving seems smoother. Oh well, i'll see how it feels when i drive it some more this weekend. Thanks Rickdogg!
Old May 13, 2006 | 01:10 PM
ac8024's Avatar
ac8024
How much smoothing is it at idle. Is it worth the money?
Old May 13, 2006 | 10:17 PM
islandsnow's Avatar
islandsnow
If you're just looking for a smoother idle, then it might not be worth it. It does feel smoother throughout the whole rev range though. I'll post again after a few weeks and see if i'm still feeling the extra torque. So far it feels like a got back some of the lower end torque i lost when adding all the intake/exhaust mods.
Old May 13, 2006 | 10:24 PM
New2350's Avatar
New2350
PRICE?? And what is it? A grounding Kit?
Old May 13, 2006 | 10:33 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
No problem buddy I am glad that you got your unit so fast. Looks nice
Also, you may have a point. I think that I gained some power down low as well and trying to do a true dyno comparison to see the difference one way or the other
Rickdogg's Avatar
Rickdogg
Out of hiatus
https://my350z.com/forum/questionable-posts/182310-fs-sun-automobile-hyper-force-systems-for-ignition-coils.html
Old May 14, 2006 | 08:55 AM
islandsnow's Avatar
islandsnow
Hey Rick,
thanks for posting the info on the unit. By the way, how was GT Live in Arizona? Post some pics if you get a chance.
Old May 14, 2006 | 09:03 AM
rico3682's Avatar
rico3682
hey guys, i installed mine and it does seem to rev up quicker and i did gain a little low end torque, but for some reason everytime i rev the engine and let off, the idle drops really really low, almost making the car stall. It come sback up to normal, but it drops soooo low. Any ideas?
Old May 14, 2006 | 10:11 AM
islandsnow's Avatar
islandsnow
Did you take off any vacuum hoses or anything else on the install? I have similar mods as you except i'm running the injen CAI. I'm not having any idle or drop in idle issues at all. Maybe try reset the ecu and see.
Old May 14, 2006 | 10:44 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by islandsnow
Hey Rick,
https://my350z.com/forum/media-share/191059-gt-live-pir-may-11-13-cyber-evo.html
Old May 14, 2006 | 10:46 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Try resetting the ecu. Did you remove any parts during install that would effect your idle?
Old May 14, 2006 | 10:57 AM
SpeedRcr's Avatar
SpeedRcr
im assuming this will work on the g's as well unless the ecu's are different on the timing and what not
Old May 14, 2006 | 10:58 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
It should work however the mounting bracket will probably need to be tweaked a bit or a new bracket may need to be fabricated altogether
Old May 14, 2006 | 11:20 AM
jcpeyton's Avatar
jcpeyton
subscribing
Old May 14, 2006 | 11:44 AM
lex350's Avatar
lex350
You may need to adjust the wires coming from the main unit into the harness. Look at the instructions for the unit, not the harness. It's not to be angled up at all? I might be off, it's hard to tell from your picture.
Old May 14, 2006 | 03:30 PM
SpeedRcr's Avatar
SpeedRcr
rickdogg you plan on getting anymore?
Old May 14, 2006 | 07:20 PM
rico3682's Avatar
rico3682
No, I did not disconnect anything that woudl affect the idle. I just diconnected the things it told me to. I tired resetting the ECU the way on the technosquare website, but I dont think it worked. Any other suggetsions for resetting it?
Old May 15, 2006 | 07:30 AM
islandsnow's Avatar
islandsnow
I think my car did something similar to that when i had a small air leak in my plenum spacer. You can always try unplugging the unit and see if it's that. Oh yeah, try using a watch when doing the TS method of resetting the ECU, it's a lot easier that way. By the way Rick, nice pics, the cars aren't bad either!!!
Old May 15, 2006 | 09:18 AM
rico3682's Avatar
rico3682
hmmm, how do i check for air leaks from the plenum spacer?
Old May 16, 2006 | 06:47 AM
islandsnow's Avatar
islandsnow
You never had this problem before the hyperforce install? I've heard of poeple with pop chargers having that problem too. Anyways, my leak was caused by a small section of the plenum gasket folded and it created a real slight gap in the back area so i couldn't see it. I knew it was the plenum because it was the last thing i worked on. The car did drop down in rpm, but then again it ran a little rough with occasional missing. Did you recheck all the wires on your install and made sure everything was clicked in?
