Do you guys use any spray gasket sealant?
Old May 15, 2006 | 08:00 PM
failsafe306's Avatar
failsafe306
Default Do you guys use any spray gasket sealant?
I'm going to be re-installing my intake manifold, lower and upper plenums in a couple days, and although I've never used it before, was wondering if using a spray-on gasket sealant would be benificial, in addition to new OEM gaskets.
This is what I'm talking about:
Attached Thumbnails Do you guys use any spray gasket sealant?-gaskseal1paint.jpg
Old May 15, 2006 | 08:26 PM
Cannysage's Avatar
Cannysage
It's not a bad idea, but I never use it.
Old May 15, 2006 | 10:54 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you tighten everything the right way and are using new gaskets... I can't really see any benefit from using that stuff.
Boosted... who knows. But even 15psi is not very much pressure on your intake manifold gaskets... I run 80+psi on ghetto *** rubber o-rings in my lab without leaks, I don't imagine leaks with 8-20psi (whatever boost you're at)
Obadabot
Jun 18, 2023 11:31 PM
burglapfd
Dec 6, 2020 01:04 PM
