Can't go past 2k RPM, what gives?
Checked the codes with the scanner and P1124 - Throttle Control Motor Relay shows to be detected.
Would you think a new relay would fix it or would the whole throttle assembly/TPS be the cause of the problem too?
The weird thing is, once i resetted the ecu, the car didnt pick up the code until 30-40minutes later. When it didn't pick up the code the "SLIP" VDC off and ABS light were on the gauge cluster constantly. Once those lights turned off the OBDII scanner picked up the code.
etkms
Jun 19, 2022 06:30 PM
