Question for the 5AT experts
Old Jun 3, 2006 | 01:52 PM
Frostydc4's Avatar
Frostydc4
Default Question for the 5AT experts
Yesterday I was using a 2006 G35 Sedan 5AT as a loaner while my car was getting serviced and I liked the "rev-matching downshift" feature on the newer 5AT (it was pretty cool to see the ECU "blip" the throttle before the tranny engaged a lower gear ). I am just wondering if this feature can be programmed (or added) to the older 5AT? I will love to have this feature on my 2003 5AT? Thanks.
Old Jun 3, 2006 | 06:24 PM
bullseye's Avatar
bullseye
I had a similar loaner car a few weeks ago. I liked the fact that in manual mode, it shifted itself into 1st gear at a stop. My tranny stays in its selected gear, even when I come to a complete stop. I have to "tap it down" to 1st gear myself. I'd like the new algorithms downloaded into my tranny, too.
Old Jun 3, 2006 | 07:11 PM
SLoG35's Avatar
SLoG35
thats interesting....b/c i thought all 5AT's automatically downshift to 1st when at a complete stop. maybe you need to get that checked. unless someone can correct me if im wrong
Old Jun 3, 2006 | 07:13 PM
Triji's Avatar
Triji
I have a '04 and mine drops to 1st on it's own as well.
Old Jun 3, 2006 | 07:15 PM
zachcrosen's Avatar
zachcrosen
Mine downshifts to 1st when stopped or rolling up to about 5-8 MPH. However, it NEVER has downshifted into 2nd. If I am in 3rd, and I slow down to about 8-10 MPH, it will stay in 3rd unless I manually downshift into 2nd.
This rev matching thing sounds kool. Anyone know if this can be changed on the earlier 5ATs?
Old Jun 4, 2006 | 03:38 AM
bullseye's Avatar
bullseye
I have an '03 5AT G35s which I purchased in July of '02. It has always shifted (or not shifted) that way. Just to clarify: If I am cruising in manual mode in 4th gear for example, and then come to a stop, the MM gear display continues to show a 4. When I start out, the car is actually in 1st gear, and will shift as needed to higher gears on its own. Of course, as long as I leave it in 4th, it won't shift into 5th.
On the loaner I used the other day, when I came to a stop, not only did the tranny shift into 1st gear, but the MM display also changed to a 1. As I rolled on the green light, I had to upshift as needed to higher gears from the git-go.
I like the new algorithm better.
Old Jun 4, 2006 | 09:03 AM
helldorado's Avatar
helldorado
You can have your dealer do a TCM reprogram. Since you have a 2003, it sounds like you have the older version of the TCM software. Talk to one of the master techs at your dealership, not the service advisor. The service advisor will confuse what you're asking for with the replacement part number for a new TCM. They can hook up the CONSULT-II and reprogram your TCM to version 31036-AL004 software for the sedan and the 31036-AL013 for the coupe.
Old Jun 4, 2006 | 11:28 AM
Cannysage's Avatar
Cannysage
? I don't get it.. is it because of your tranny upgrades? nobody else has to downshift to 1st when coming to a complete stop.
Old Jun 4, 2006 | 07:00 PM
ATL_Red_G35's Avatar
ATL_Red_G35
I have an 03 and mine manually down shift to 3rd during braking/low speed, and down to 1 when I came to a complete stop.
Old Jun 5, 2006 | 03:38 AM
rcdash's Avatar
rcdash
It is the tranny firmware version as posted above.
Old Jun 6, 2006 | 05:54 PM
guy121's Avatar
guy121
I wonder if anyone is going to answer the OP's original question rather than derail the whole thread...
Old Jun 6, 2006 | 06:50 PM
helldorado's Avatar
helldorado
I thought I already did.
Old Jun 7, 2006 | 12:18 AM
guy121's Avatar
guy121
oh sorry thought you were suggesting that for the people who were talking about how when in manual mode it doesn't downshift to 1st...
So you can actually get a software reprogram to allow for the rev-matching feature? Any idea on cost, because I'd love to have something like that. I used to blip the throttle when I downshifted in my old car so it wouldn't bog down.
Old Jun 7, 2006 | 04:42 AM
helldorado's Avatar
helldorado
Now that I think about it, you'd have to get an update on the ECU too for the rev-matching. TCM controls / monitors transmission speed and gearing, but the ECU sends the control signals for the throttle body and injectors.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
