Gears dont want to go in...
Old Jun 7, 2006 | 04:44 PM
Gryphin's Avatar
Gryphin
Default Gears dont want to go in...
Anyone else have this problem? Im usally great at shifting... but sometimes, if if i do a couple runs (1-2-3rd let off) its sometimes hard to get the car to go into 2nd... even with the clutch to the floor...
Old Jun 7, 2006 | 06:41 PM
Gryphin's Avatar
Gryphin
this is after the motor is warmed up, and ive been down the track a couple times..*could it be getting too hot?*
Old Jun 7, 2006 | 06:49 PM
visionboy's Avatar
visionboy
wow and you got 2006? mine is 2005 and have the same problem, esp in 2nd but 3-6 is pretty hard to get into at times. Its very notchy... kinda sucks
Old Jun 7, 2006 | 06:51 PM
Gryphin's Avatar
Gryphin
it only happens if im running her a bit... during normal driving shes fine... but sometimes... shifting out of 1st at 7k she doesnt want to go into 2nd..
meh 06 or not, its still a z with all the same problems
Old Jun 7, 2006 | 07:00 PM
LeMansZ33's Avatar
LeMansZ33
I have an 06 and it never goes into first, its always hard to get into second, third and fourth, but only randomly, other times it will go in gear and I cant even feel it going into gear
Old Jun 7, 2006 | 07:07 PM
BamBam's Avatar
BamBam
I also have the same problems.
When I have been riding her hard, she really does not want to shift into 2nd.
This is a REAL BIATCH when I am doing a lot of runs on the strip as I have to leave it in neutral, let of the clutch then try it again.
Old Jun 8, 2006 | 03:31 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
clutch to the floor... that is the problem...
try putting the clutch in only half way...
Old Jun 8, 2006 | 11:31 AM
dingobiatch's Avatar
dingobiatch
wait, why would clutch to the floor be the problem?
i am experiencing the same thing, but i thought it was cause i wasnt putting the clutch all the way to the floor... until a few times now i have had it completely to the floor, try to go into 2nd (this is after full acceleration in 1st) and it doesn't go into 2nd - and I completely grind the gear. Granted, I have only been driving stick for a few months now, but I thought this wasnt supposed to happen if you have the clutch all the way to the floor.
And I have a 2006 btw.
Old Jun 8, 2006 | 11:43 AM
I found 157 threads addressing transmission problems...
https://my350z.com/forum/search.php?searchid=1462083.
No model year has been spared.
Old Jun 8, 2006 | 11:47 AM
Mike Wazowski's Avatar
Mike Wazowski
So you think people should use the search function David?
Old Jun 8, 2006 | 11:55 AM
Yes. But I wanted to make the suggestion politely.
Old Jun 8, 2006 | 12:00 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
My '06 has been giving me a hard time about going into 6th recently...pissing me the **** off!
Old Jun 8, 2006 | 01:30 PM
Gryphin's Avatar
Gryphin
well i know that the 05s and before had the problemi was just checkin with my 06 buddys to make sure that everyone else was having the same freakin problem... ive tried almost ever depth of clutch in and i still get the problem after a couple runs....
And I too have a problem getting it into 1st sometimes when the motor is cold or warm... i just slightly release the clutch and push it back in and it will let it go in... or rev up the motor and sometimes that works too...
Old Jun 8, 2006 | 01:37 PM
Z_rican's Avatar
Z_rican
IIt's hard for me to shift in to 2nd also. If I shift really slow I grind the **** out of 2nd. I have had the transmissinn for maybe 1 month or so.
Old Jun 8, 2006 | 01:41 PM
Jason@Performance
Performance Nissan
if you hyper extend the pressure plate (harder to do with standard size clutches but does happen especially when people do the pedal adjustment mods) the clutch re-engauges itself and its like you arent even pressing down on it...
Old Jun 9, 2006 | 04:07 AM
Gryphin's Avatar
Gryphin
i havnt touched the clutch engaugement point... but i will try not to push the clutch in all the way..
Old Jun 9, 2006 | 09:45 AM
Jason@Performance
Performance Nissan
in my Z... I had to put the car in 2nd gear before I could put it into first...
there are a few people on this board who have put in pedal stops to keep their clutch pedal from going to the floor when using OEM sized clutches... it helped made shifting smoother...
Old Jun 9, 2006 | 05:02 PM
TruBluZ's Avatar
TruBluZ
I used to have problems shifting to 2nd during hard runs at the track. Luckily, I haven't had the problem recently. I just have problems keeping traction.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
