Cusco or Nismo???
Old Jun 12, 2006 | 06:25 PM
Super Avan Z33's Avatar
Super Avan Z33
Question Cusco or Nismo???
I'm trying to get the Cusco or Nismo LSD for my 04 base 350z, just want to get some advice from you guys, which one should I go for?
Old Jun 12, 2006 | 06:27 PM
negotiator's Avatar
negotiator
Cusco 2 way.
Like this.
Old Jun 12, 2006 | 06:28 PM
Wholey Smokes's Avatar
Wholey Smokes
I went with the Nismo for my Base since it comes with the stub axles etc.
Old Jun 12, 2006 | 06:29 PM
negotiator's Avatar
negotiator
Originally Posted by Wholey Smokes
06 PPW 350Z: Can't make up my mind on whether to turbo or not.
Turbo.
Old Jun 12, 2006 | 06:32 PM
vince1611's Avatar
vince1611
Old Jun 12, 2006 | 07:21 PM
Kwame's Avatar
Kwame
The Nismo LSD is a great product especially since you have a base and it comes with the stub axles. The Cusco RS is a better differential because it has a smoother engagement and it is quieter. Its downside is that it is more expensive and does not come with the stub axles.
Old Jun 13, 2006 | 10:44 AM
bluesaint's Avatar
bluesaint
My Brand new in box cusco type RS lsd is for sale. 1.5 or 2 way is possible.
https://my350z.com/forum/showthread.php?t=197082
Old Jun 13, 2006 | 12:27 PM
sentry65's Avatar
sentry65
the burninator
if you go nismo USE REDLINE FRICTION MODIFIER
OMG it makes a difference
using synthetic oil helps too. I use redline
my nismo LSD works very well and is very smooth with the right oil setup
if you use cheap oil and no friction modifier, it's going to suck and make noise and clunks and jerks and run hotter
Old Jun 13, 2006 | 01:07 PM
Super Avan Z33
Just done the research, looks like everyone prefer the Cusco over the Nismo, b/c the Cusco run smoother, no noise and definitely no *clunking* sound. But no wonder why everybody like to buy the Cusco without all the complete parts to do the install and cost more than the Nismo?
Old Jun 13, 2006 | 03:19 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
because, as you just answered for yourself, it is a better all around diff. The NISMO is a great unit - identical in fact to the Cusco MZ model. Problem is, that is does not use a spring loaded hub on the disk, and even with the best of fluids and proper breakin, it can be a bit finicky in around town driving.
The Cusco is a bit more expensive, but it has the springs for the disks making it much smoother overall, and it's adjustable from a 1.5 to 2 way, in addition to being adjustable for lockup % (NISMO is also adjustable for lockup)
Most of our customers who have bought the diff had VLSD's as standard in their cars, so the "extra" parts they got with the NISMO were a waste for them anyway - given this and the close price of the 2 pieces, is why many people go Cusco.
Both are excellent units though!
Old Jun 15, 2006 | 01:58 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
as said above...
NISMO because it comes with everything you need to install into your Base...
stub axles / side oil seals / side bearings...
http://www.mynismo.com/products/?id=2526&rsku=0
Old Jun 15, 2006 | 03:52 PM
1nate7's Avatar
1nate7
How much did you use? I am running Redline 75w90 fluid but still get a lot of chatter. It looks like the Redline friction modifer comes in a 4 oz bottle. I don't want to add too much though, so if anyone has gone through some trial and error with this already please chime in.
Old Jun 15, 2006 | 03:58 PM
sentry65's Avatar
sentry65
the burninator
I've always had my shop do my diff fluid, but I think they use about half or 2/3 of the bottle - dunno would have to look at the bottle
Old Jun 15, 2006 | 04:36 PM
1nate7's Avatar
1nate7
Thanks, I'll probably try half (2 oz) and go from there.
Old Jun 15, 2006 | 05:01 PM
sentry65's Avatar
sentry65
the burninator
i dunno, i think i'd just go by whatever the instructions say
Old Jun 27, 2006 | 07:58 PM
1nate7's Avatar
1nate7
Instructions just say to keep adding it until the chatter/popping goes away and be careful not to add too much. I added about 2.5 ounces and now its perfect. Still a little noisy cold, but very smooth once warmed up.
Old Jun 27, 2006 | 08:31 PM
MIAPLAYA's Avatar
MIAPLAYA
I don't mind the chatter much... but yes the Nismo one is clunky for street driving. It also has a weird feel in some corners. On some variable angle corners I noticed if I lift off the throttle a little the Nismo seems to unlock or something like that...its a very weird feeling but still managebale. I guess maybe I shouldn't be lifting though
Old Jun 28, 2006 | 10:53 AM
spf4000's Avatar
spf4000
I dunno if you already made your decision, but I have an ATS LSD for sale if you're still looking. In both performance and noise issues, it's much superior to the Nismo or Cusco.
Old Jun 28, 2006 | 11:47 AM
sentry65's Avatar
sentry65
the burninator
the ATS also only works with the 3.5 final drive unless you go thru a huge pain in the *** to get it to work with a 3.3 or 3.9
New brownie
Dec 26, 2013 06:15 PM
zillinois
Apr 26, 2010 10:14 AM
dchi_t
Dec 30, 2004 03:18 PM
