Flywheel/clutch recommendations for a daily driver
Old Jul 16, 2006 | 10:39 AM
hunter6's Avatar
hunter6
Default Flywheel/clutch recommendations for a daily driver
I've done a search but I need some more help. I'm looking to lighten up the driveline but I don't want to live with a lot of excess noise. Which flywheel and/or clutch set up that does this?
Thanks
Old Jul 16, 2006 | 11:53 AM
plumpzz's Avatar
plumpzz
JWT Flywheel/clutch combo
Old Jul 16, 2006 | 11:58 AM
syndacit's Avatar
syndacit
The one and only
Old Jul 16, 2006 | 03:49 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
any lightweight flywheel is going to add some noise...
JWT flywheel / JWT Clutch
JWT Flywheel / NISMO clutch
those are the two best ways to go for the daily IMHO...
http://mynismo.com/categories/?id=2277
Old Jul 16, 2006 | 06:39 PM
hunter6's Avatar
hunter6
What type of noise should I expect from the recommended set-ups? Under what conditions is the noise noticeable?
Thanks
Old Jul 16, 2006 | 08:06 PM
Jason@Performance
Performance Nissan
at idle if you are not pressing the clutch pedal in you hear some flywheel chatter (TOTALLY NORMAL) its there with the stock set up just very soft...
if in gear below 2000 RPM and accelerating you may hear chatter as well... solution, be in higher RPM in gear accelerating... the RPM in which the sound occurs depends on the set up... the heavier the flywheel / clutch combination the lower RPM the sound stops at...
Old Jul 16, 2006 | 09:44 PM
hunter6's Avatar
hunter6
You guys all satisfied with your setups? Noticeable performance gain?
Thanks
Old Jul 16, 2006 | 10:10 PM
Rick06Z's Avatar
Rick06Z
Old Jul 16, 2006 | 11:11 PM
Jason@Performance
Performance Nissan
with the lighter flywheel you gain acceleration horsepower... not peak horse power...
with the lighter flywheels (lighter the experience is faster) you get faster engine response... so when down shifting, rev-matching is easier...
Here is a video clip of my Z with a very light weight clutch and flywheel setup (this set up is no longer avaialble but total weight clutch & Flywheel was 16lbs)
http://members.aol.com/performancenismo/tilton.avi
Old Jul 20, 2006 | 05:26 PM
hunter6's Avatar
hunter6
Sorry for the dumb question but what is it about the flywheel that makes the noise?
Old Jul 21, 2006 | 02:45 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the fact that it's lighter
weight is an insulator
Old Jul 22, 2006 | 03:54 PM
hunter6's Avatar
hunter6
what noise does the extra weight insulate? from the engine? crank? something with the flywheel itself?
Thanks
350Z_Al
Oct 29, 2020 07:44 PM
May 30, 2017 03:28 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
