Input on Debate.
Old Jul 22, 2006 | 11:48 AM
Gators2001's Avatar
Gators2001
Default Input on Debate.
I have been having a conversion with another member about the possibilty of doing engine work without removing the engine. We are talking in theory, im not a mechanic.
Now there many different elements to the conversion and points of disagreement.
But the one Im bring up for input is the ability of replacing the stock rods from underneath the car without removing the egine. It is agreed that the job would be best performed with the engine removed.
But what I have trouble believing is that the rods could be removed without removing the crank. I can see some of the bolts being replaced, but the rods. Other things I see causing a problem are rotating the crank, would the piston slide easily?, and is it possible to remove the oil pan parts to get at the short block?
This just sounds to hard from that angle.
Old Jul 22, 2006 | 02:09 PM
booger's Avatar
booger
If Im reading your post right .
The rods do not go in from the bottom of the motor . They are bolted to the pistons and both are slid in place from above
Old Jul 22, 2006 | 02:15 PM
Gators2001's Avatar
Gators2001
yea thats what i was trying to convey.
the bottom is a half circle.
but the idea he had was pulling them down, then removing the from the piston while leaving the piston in the sleeve. I dont see it being possible.
It was just an interesting idea.
Old Jul 22, 2006 | 02:20 PM
superchargedg's Avatar
superchargedg
Damn Noobs
it wont work,the piston has to come out to remove the rod.the pin has to be removed before the rod will come out,it has to be done from the top.and tell your friend that there is this huge thing called a crankshaft in the way.
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
