Does Nismo LSD work with AT final Gear?
Old Aug 6, 2006 | 10:50 AM
whiteG35c's Avatar
whiteG35c
Default Does Nismo LSD work with AT final Gear?
I am in market for Nismo LSD and I was looking through Performance Nissan web site. they said that LSD will not work with AT final gear. Is this true?
Old Aug 6, 2006 | 12:03 PM
sentry65's Avatar
sentry65
the burninator
it might not drop right in easy, but it could probably be made to work
Old Aug 6, 2006 | 12:44 PM
helldorado's Avatar
helldorado
No, the 3.3 ring gear is 10 mm thicker than the 3.5. Because the diff attaches to the ring gear, that thickness difference keeps the 3.3 from working with differentials designed for the 3.5.
Old Aug 6, 2006 | 03:09 PM
whiteG35c's Avatar
whiteG35c
so that means there is no aftermarket LSD that will work with AT final gear?
Old Aug 6, 2006 | 03:53 PM
helldorado's Avatar
helldorado
Quaife and Cusco are your only 2 options. Quaife is a drop-in for open diff, Cusco is a drop-in for VLSD. If you have VLSD and go Quaife, you need to replace the axle stubs, and vice versa for Cusco.
Old Aug 6, 2006 | 05:18 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep Cusco makes an AT specific rear limited slip
http://www.z1auto.com/prodmore.asp?m...ine&prodid=518
Old Aug 6, 2006 | 07:06 PM
whiteG35c's Avatar
whiteG35c
just want to make sure, I have 6mt with AT final pumpkin so that means I have to get LSD for AT to make it work right?
sorry for dumb questions.
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
Shane86
Sep 17, 2015 05:33 PM
OperatorAF
Sep 13, 2015 11:36 AM
