Good News: ECU outlook good
Old Feb 27, 2003 | 01:58 PM
Chebosto's Avatar
Chebosto
Thumbs up Good News: ECU outlook good
I got an email from Technosquare today concerning my ECU i sent to them in Japan..
They are downloading the data right now. It seems like the US spec ECU has the same hardware as JDM spec one. They seem to have a way to work around the key inmobilizer too (means that you can swap ECU around, mainly theft protection if you put in a different key it will check the ecu serial # to start the car).
So far it looks good...
Techtom flash reprogramming device lets you overwrite the ECU with your performance data from their PC. so pretty much means that most of the programming can be done either thru in-car reprogramming from diagnostic port and direct reprogramming from ECU connector on the bench thats hooked up to a computer
The ECU (along with a report) will return to the 'States next week.
i'll keep everyone posted.
--Cheston
Old Feb 27, 2003 | 02:07 PM
mattwp103's Avatar
mattwp103
Talking
Awesome! cant' wait to see results
Old Feb 27, 2003 | 02:19 PM
fdao's Avatar
fdao
Keep up the good work
Old Feb 27, 2003 | 02:20 PM
Moodie's Avatar
Moodie
Minivan Racer
Talking Let us know!!!
Hopefully the car will have some noticable gains and runs more efficient.
Can't wait!!
Old Feb 27, 2003 | 04:43 PM
Mr Fairlady's Avatar
Mr Fairlady
WORD UP! bout damn time!!
<-------Mr.Fairlady wants a ECU upgrade badly!!!
Did they charge you for that?
Old Feb 27, 2003 | 05:42 PM
Chebosto's Avatar
Chebosto
Patience dude. i got work to deal with ya know. :P
Old Mar 3, 2003 | 07:15 PM
Intrepid's Avatar
Intrepid
Chebosto, Great News. Keep us posted!
Old Mar 3, 2003 | 07:18 PM
Chebosto's Avatar
Chebosto
the ECU comes back to the US this week,
man. i just hope they have some good news.
im stoked. i mean. how bad *** would that be? finally a US spec ecu..
Old Mar 3, 2003 | 07:25 PM
JeffR116's Avatar
JeffR116
YES!!!!!
I can't wait to hear about the specifications. That's good news indeed. Keep us Updated!
Old Mar 4, 2003 | 08:56 AM
hokie350's Avatar
hokie350
All you need with your new ECU is a little computer that links up the ECUs from two different cars. It only needs two functions... Copy, and Paste.
Old Mar 4, 2003 | 10:16 AM
Chebosto's Avatar
Chebosto
i only wish it was that easy.
alot more than that has to happen.
if you've ever seen actual ecu programming done, its pretty crazy. everything is in Hex code... and you'll have to manulaly search for the certain number sequences to change...
but it might be slightly different with the newer systems out now...
Old Mar 4, 2003 | 11:00 AM
mattwp103's Avatar
mattwp103
ches...in another thread didnt i read that its supposed to be comming in today? well i hope it is and can't wait to see ur gains
Old Mar 4, 2003 | 11:39 AM
NismoEagleRock's Avatar
NismoEagleRock
in the words of snoop, "tizzight"
Old Mar 4, 2003 | 04:25 PM
Chebosto's Avatar
Chebosto
Hey guys-
i briefly spoke the guys at Technosquare, they want the ecu for another week, to try to get more info about it, so i said ok, as long as they think they can have something productive... i guess its just patience.
i know everyone wants a chip now but hey, if no one takes their time to do it right the first time, there's no point in getting anything out anyway...
i will keep this thread updated when i get more info.
thanks
--Cheston
Old Mar 4, 2003 | 04:41 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
So they are doing a dump right now, but are they going to modify anything on your ecu? did you tell them to raise redline, and change the a/r ratio? Thanks!
Old Mar 4, 2003 | 05:34 PM
Chebosto's Avatar
Chebosto
This is what i told them to look for:
-Rev limiter,
-Immobilizer Bit
-A/F codes
-Timing.
-O2 sensor "release" <~~they prolly wont do this cuz its 'illegal' to mod these things, but would help if your stock cats happen to fall off some how.
-If we do have a speed limiter, to find that too.
Old Mar 4, 2003 | 05:40 PM
Intrepid's Avatar
Intrepid
Looks Good. Yes, the Z is suppose to have a speed limiter set at 156 MPH.
Old Mar 4, 2003 | 05:53 PM
phile's Avatar
phile
so i wonder how fast the Z is ungovernered?
Old Mar 4, 2003 | 05:55 PM
mattwp103's Avatar
mattwp103
man the suspense is killing me and now another whole week!!!!......ahhhhhhhh!!!
Old Mar 4, 2003 | 06:05 PM
Chebosto's Avatar
Chebosto
Mind you, the longer they have my ecu.. means i cant drive it.
i could push it.... but....
Old Mar 4, 2003 | 06:33 PM
Intrepid's Avatar
Intrepid
His brain....it's....it's.....GONE !!!
Old Mar 4, 2003 | 06:43 PM
mattwp103's Avatar
mattwp103
i was just wondering how does technosquare know that this will provide any gains? do they have a US-spec 350z there? im confused...i just hope this will provide huge gains
Old Mar 4, 2003 | 06:48 PM
YourMomma's Avatar
YourMomma
Default ECU Source
I can't belive there's no one in this forum who programs in Assembly. There has to be someone.
Does anyone have the dump from the ECU? I'm sure if we have the contents it woudn't take too long for someone to tear it apart...
Old Mar 4, 2003 | 07:38 PM
dwnshift's Avatar
dwnshift
We also have one over in Japan getting re programmed. Well see how it goes.
Old Mar 4, 2003 | 07:40 PM
mattwp103's Avatar
mattwp103
im just wondering what company is doing it?
Old Mar 4, 2003 | 07:46 PM
dwnshift's Avatar
dwnshift
To be honest I have no idea but I know it arrived there yesterday for the FEDEX tracking number. Well see hoe it goes. Should be back here next week.
Old Mar 4, 2003 | 07:48 PM
mattwp103's Avatar
mattwp103
cool
Old Mar 4, 2003 | 07:58 PM
Wags's Avatar
Wags
I program only in assembler, but it's not that simple. I didn't read the whole tread, just skimmed. The dump only takes a minute, figuring out what the dumped program is doing takes some time. Does any one know what type of CPU is used? Then you have to know the address or port of each input signal, using the logic of the program to try and deduce that... O2, throttle position, etc. And then of course just doing the reverse engineering is illegal, but I don't really agree with that. I haven't done this sort of thing since the 80's and things have changed a little, but they have prolly figer'd out lots but have to go over and over to try to make sure they are interpreting things right. But I WANT ONE... just let us load new maps and maybe disable or change a few things like rev, speed... etc. Sorry for babblin, just had to get on this thread.
Old Mar 4, 2003 | 08:21 PM
YourMomma's Avatar
YourMomma
Agreed, its not super simple, but it can be done.
As to legality... lets not go down the road of the DMCA/Reverse Engineering/etc. We don't have enough room on this board.
Yeah! A loadable/programable ECU would be VERY cool.
Old Mar 4, 2003 | 08:34 PM
Chebosto's Avatar
Chebosto
They have MY us-spec ECU, which they will compare with JDM, see if the JDM program will work on mine, then i get mine back, and dyno tune it with their laptop attached to my car running with their interface..
as for loadable programs. its a matter of plug-in-play with their interface unit and loading A/F maps already done on the computer.. sounds crazy but doable..
as for when the ECU resets, it will NOT erase the program that will be FLASH'd on.. sweet! so in all likelyhood, Turbo/NOS applications COULD be programmed...
DWNSHIFT: who did you sent it to? or is that trade secret
in all reality, ECU would probably be the easiest mod to do. no hard elbow greasing! hehe.
