Difficulty in Shifting gears
Old Aug 25, 2006 | 11:52 PM
throughthefire's Avatar
throughthefire
Default Difficulty in Shifting gears
Hey guys,
For some reason I notice a a reluctance when switching from 1st to 2nd gear. I'm not all too mechanically inclined, therefore I'm not sure what could cause this. I was hoping you guys could help me out. It seems like I have to more or less force it in to 2nd gear rather shift with ease. Thanks in advance.
Old Aug 26, 2006 | 12:04 AM
JDM_ZED33's Avatar
JDM_ZED33
i had trouble at first driving the z. i use to try to shift as fast as possible and take my foot out of the clutch too fast from 1st to 2nd therefore mising the gear and going into neutral....maybe thats what your doing?
Old Aug 26, 2006 | 12:13 AM
throughthefire
Yea, I misshifted a couple times in the beginning but I've gotten used to it and I'm pretty sure I'm shifting correctly. I don't hear any grinding sounds so I guess nothings wrong. However, it just seems more notchy than before. Maybe its just in my head
Old Aug 26, 2006 | 02:25 AM
JDM_ZED33's Avatar
JDM_ZED33
yeah the clutch was hard for me to learn at first....it just takes time to get used to it
Old Aug 28, 2006 | 09:28 AM
ANXIOUZ's Avatar
ANXIOUZ
Getting into 6th for me is a pain. I have to kinda pause for like 2-3 seconds before it goes in.
Old Sep 1, 2006 | 05:53 PM
DIGItonium's Avatar
DIGItonium
My 2nd gear likes to pop back out, and it's a CD-008 tranny from Jan/Feb this year. I had mine replaced around 25k miles, and it's an '03.
Old Sep 1, 2006 | 06:05 PM
deviljon's Avatar
deviljon
i get that problem with my 06 as well. for 1st to 2nd shifting i just step further down on the clutch and it shifts smoothly. for other gears i can pretty much tap the clutch and shift...
Old Sep 1, 2006 | 06:11 PM
masterj26's Avatar
masterj26
mine likes to pop out of 2nd and is hard to get into 5th gear
Old Sep 1, 2006 | 06:38 PM
plumpzz's Avatar
plumpzz
I had the original tranny in an 05 and it was very notchy. 5th gear began to grind and it was replaced under warranty for the 009 revision transmission. This 009 is MUCH better. I dont have to fight the gears to let me switch. Instead, when i want to shift, it feels like it just pops into palce. They definately fixed something because its much smoother.
Old Sep 1, 2006 | 11:11 PM
DIGItonium's Avatar
DIGItonium
ARgh... 009's been out at the time I had my tranny replaced. I requested for that one, and they told me I have a brand new '06 tranny... the 008 >.< They said -009 didn't exist.
Old Sep 1, 2006 | 11:56 PM
silver nismo's Avatar
silver nismo
I miss shifted a couple of times from 1st to 2ed but i still feel verey bad about it so i think i hardly rev too much on 1st any more coz i think it will scratch.
Old Sep 2, 2006 | 12:08 AM
Z4Zoro's Avatar
Z4Zoro
Originally Posted by mc350z
this is fairly a common trait of the Z. its very "notchy" going into 2nd, unless you hear a grinding sound consider it normal. ive has 2 transmissons and both have been hard going into 2nd. for me its worse when you start the car up after you go a little ways down the road it gets a little better but never perfect
Yea, I agree this is normal. You have to use a little force into 2nd and sometimes you can hear the car going into gear. Wish they did a better job on the 1st to 2nd gear shift. I usually like to take the 1st to 2nd slower than all the other gears. I give 1st a little gas before I shift and then clutch and pull down slowly. Usually works for me. Just give it a little gas.
BTW throughthefire, if you go to the dealer they will also tell you there is nothing wrong. You'll get used to it.
Old Sep 2, 2006 | 07:03 AM
doug's Avatar
doug
shifting an 009 Tranny = is like a ***** going into a warm wet vagina or a hot knife through butter
Old Sep 2, 2006 | 07:34 AM
deviljon's Avatar
deviljon
whats an 009 tranny and what do i have if i have an 06 model?
Old Sep 3, 2006 | 07:57 AM
doug's Avatar
doug
009 tranny is the 9th revision of the Nissan 6spd Transmission that they are currently putting in when you go in for a transmission replacement. I am not sure what your car has, you would have to look at the tranny VIN number and see
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
apex locator
Oct 6, 2015 05:58 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
