ATS Carbon LSD
on
ATS Carbon LSD
I'm looking to get this ATS Carbon LSD and wonder where I can find the best price? also the parts I'll need for installation? Are the stub axles the only parts I need?
Thanks for your help guys
Forged Performance
Forged Performance
With a track model, you will not need stub axles or anything extra. Most people will also purchase a pair of OEM bearings/races, since you will likely damage your original ones if you try to remove and reuse them.
We have one in stock....$1299 shipped. http://www.forgedperformance.com/sto...5&cat=0&page=1
on
oh! will Cusco RS be better to pair up with the central 20 3.9 final drive?
how can I confirm the 3.9 gears will work with either ATS or Cusco?
Thanks!!
Thanks!!
on
Great! I might just go with Cusco....since cheaper : )
Cusco RS is not that nosiy right? I track the car quite a lot, is 60% good enough? I'm afraid 80% lock will be too rough?
Thanks for the great help
Forged Performance
Forged Performance
The ATS and Cusco have identical ring gear shelf heights. Their dimensions are identical. So if something will work on the Cusco, it will work on the ATS.
When the Cusco is stacked at 60% lock, it probably wont grab as much with the 3.9 ring gear. The ATS will be a little bit grabbier with the 3.9, since its 100% lock , but with carbon discs, and their oil, it works fine.
Either diff will suit you with 3.9 gears.
Former Sponsor
on
I'd still recommend it at 60% lockup for street and anything but all out long track use. I've had the 3.9 and Cusco diff in my own car now for nearly 2 years, and it's worked perfectly
11-09-2020 10:27 AM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
