loud gears
Old Sep 21, 2006 | 03:00 PM
djfujiyama's Avatar
djfujiyama
Default loud gears
My mom commented that she could hear me shift gears quite audibly while standing by the curb. (going from 1st to R back to 1st). She was concerned that something might be wrong because it was so loud. A friend of hers said it could be because of worn bushings. It's an '03 with 30k easy miles on it. I dont notice the gears being loud in the vehicle. Is this normal?
Old Sep 21, 2006 | 03:21 PM
roast's Avatar
roast
Normal. Even if you're double clutching 1>R R>1 like you should be doing, it will still make noise.
Old Sep 21, 2006 | 03:33 PM
efx's Avatar
efx
Push clutch farther in... its not the transmission.
There are 3 different systems when changing gears.
1. Cable
2. Crank
3. Auto
I believe the Z's have crank thus the noise while moving gears.
You will notice the difference w/ the cable shifter, less noise and less muscle movement. You kind of have to grab and pull harder w/ the cranks.
Old Sep 21, 2006 | 04:35 PM
Cozmo's Avatar
Cozmo
i have the same thing, when drivin slow with the windows down i can hear the clunk goin into a gear...it makes alot of noise and im not a fan of it but i live with in....about 37K miles on my 03
Old Sep 22, 2006 | 03:18 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the transmission will make some amount of noise when going gear to gear while stationary - its just the physical mechanism moving
The transmission should be free of clunks and should be totally smooth while stationary or moving. Anything less than that, and you have some sort of a problem
Old Sep 23, 2006 | 05:55 PM
znot's Avatar
znot
i too have this loud noise thing,......curious, is there anything that can be tightened under there?
Old Sep 23, 2006 | 11:35 PM
theanswer0127's Avatar
theanswer0127
mines loud too. i was wondering if there's anything wrong with it. also when u accelerate slowly from low rpms, i hear this metal/spinning sorta sound that getting quicker when u speed up and eventually goes away. usually in 4th gear i think. do u guys know what it is?? or is that normal??
Old Oct 4, 2006 | 04:32 PM
Renegadesrun's Avatar
Renegadesrun
.....and i as well. Just like theanswer.
Old Oct 4, 2006 | 11:20 PM
Machupo's Avatar
Machupo
the clunk is normal as is the spinning sound... IIRC, the spinning sound are the synchros.
i like the noises, but then i also drive the car like I stole it so I rarely hear anything other than exhaust and tires
Old Oct 5, 2006 | 07:56 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
As it is mentioned in the Top 100 Questions Thread, the transmission is noisy. Most transmission noises you hear are normal.
Please click the link in my signature and skim through it before starting anymore threads, as your questions may have already been answered
Furthermore, the Z's transmission is rather noisy. Shifts will seem especially noisy when you are in an enclosed parking lot, tunnel, etc.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
