quick final drive swap help
Old Oct 16, 2006 | 06:38 PM
bonusfrag's Avatar
bonusfrag
Default quick final drive swap help
Hi all,
I know I am being a lazy **** on this. I did some searches and reading on it, but I just want to double check before I pull the trigger.
I am looking to replace my 04' 5AT 3.3 fd w/ a 3.5 fd from a '04 6MT touring. I just need the gear and pinion right? No messing w/ the pumpkin and lsd or anything?
Thanks in advance
Old Oct 17, 2006 | 04:52 AM
bonusfrag's Avatar
bonusfrag
can any veterans do a quick chime in and send me on my way? thanks
Old Oct 17, 2006 | 05:08 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by bonusfrag
Hi all,
Thanks in advance
replace the whole pumpkin,dont just try and swap the internals cause it wont work.the 3.5mt pumpkin has larger gears then the 3.3at rear.swapping the pumpkin is easy,you can do it on jack stands.
Old Oct 17, 2006 | 06:01 AM
orions empire's Avatar
orions empire
sorry guys, kind of newbie in mechanics. What do you call the pumpking, I am trying to translate to spanish, but something here doesnt match. Is the gears in the trans. or are the gears of the differential? also, should I change the full assembly of the differential or what? please understand the translation in spanish is not the same. Please help!
Thank you in advanced!
OE
Old Oct 17, 2006 | 06:31 AM
superchargedg
Damn Noobs
OE
its the rear differential complete assembly.
Old Oct 17, 2006 | 06:50 AM
bonusfrag's Avatar
bonusfrag
Thanks superchargedg. Appreciate the info
Old Oct 17, 2006 | 12:18 PM
z-u-later's Avatar
z-u-later
I just swapped my A/T 3.3 FD to an M/T 3.5 FD. I had to do the entire pumpkin and it was a straight swap.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
