Timing Belt???
Old Oct 19, 2006 | 01:52 PM
StreetOC192's Avatar
StreetOC192
Question Timing Belt???
I know we have timing chains on the 3.5L. I was just browsing around the vividracing.com site and came accross a timing belt for the 350z? Is there a conversion to use a belt and if so, WHY? I'm not interested in making the switch, just curious.
http://www.vividracing.com/catalog/p...oducts_id/1364
Old Oct 19, 2006 | 01:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I think that's just the regular engine belts. "timing belt" is a misnomer.
You are correct, we have a timing chain on our engines. It's under the timing cover which faces the front of the engine bay.
Old Oct 19, 2006 | 01:54 PM
thirty5ounces's Avatar
thirty5ounces
i was sure that all new Z's had timing belts.........
Old Oct 19, 2006 | 01:57 PM
StreetOC192
That's one heck of an expensive drive belt then. Thanks for the quick response. I can rest easy tonight now
Old Oct 19, 2006 | 02:04 PM
superchargedg's Avatar
superchargedg
Damn Noobs
alert newb post.
Old Oct 19, 2006 | 03:04 PM
dkmura's Avatar
dkmura
General & DIY Moderator
The link clearly shows those are drive belts off the crank pulley for the 350Z's a/c, power steering, etc. No details on why or how they are "super strong". The OEM belts (which should be relaced periodically) are not as expensive.
Old Oct 22, 2006 | 12:09 PM
boma's Avatar
boma
So since we have a timing chain, does that mean we don't have to change it ever? I don't see anything about it in the service manual.
Old Oct 22, 2006 | 12:24 PM
JETPILOT's Avatar
JETPILOT
No the chain does not need to be replaced.
JET
Old Oct 22, 2006 | 07:13 PM
dkmura's Avatar
dkmura
The timing chain is considerably stronger and more durable than a textile belt. Its lifespan usually exceeds that of the engine, although I always replace them (together with the pulleys and guides) whenever I rebuild a motor.
Obadabot
Jun 18, 2023 11:31 PM
Fixxxercask
Nov 9, 2015 11:10 AM
