Help!!! OIL PRESSURE 130 PSI?????
Old Oct 24, 2006 | 05:03 PM
shifty711's Avatar
shifty711
Default Help!!! OIL PRESSURE 130 PSI?????
Hey everyone, I just got an Oil change and now my oil pressure is stuck on 130 psi the whole time the car is on, idling, driving. Whatever. What could have caused this.
Im affraid they are going to deny my service becuase of my aftermarket parts.
Has anyone had this experience and what do you guys think it could be????
Old Oct 24, 2006 | 05:06 PM
Monsta's Avatar
Monsta
Check the level. The dip stick is hard to read and the service center may have overfilled it.
Park it on as level surface as you can find and let it sit for about 5 mins or so (less time if its at operating temp). Take the dip stick out, wipe it off, and reinsert it. Take it out again and check the level. And even then it is hard to get an accurate read.
Old Oct 24, 2006 | 05:56 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you can try to disconnect the battery and go from there (resetting the ecu). If not, it sounds like your sending unit went bad
Old Oct 24, 2006 | 10:58 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
My bet would be damaged sensor during your oil change.
Take it back there and show them that they fukked up.
Old Oct 27, 2006 | 06:56 PM
meshugineh's Avatar
meshugineh
I am having the same issue. Started today but my last oil change was ~2800 miles ago. I'm going to unplug to battery and see if it works, if not then I'll take it in.
Old Oct 28, 2006 | 03:55 AM
undrgnd's Avatar
undrgnd
Posted many times here before. Pegged out oil pressure means a damaged oil sensor. Stop wasting your time.
It is so easy to replace, anyone could do it. If you can change your oil filter, you're in. It's right there next to it IIRC, and all you need is a BIG wrench, or transducer socket. Unless it's covered by warranty, you're better off buying a wrench or socket and doing it yourself. The labor alone will pay for the tools.
Old Oct 28, 2006 | 11:50 AM
shifty711's Avatar
shifty711
yeah, damamged sensor, got it fixed, it was covered by warranty. THanks for the help
Old Oct 28, 2006 | 12:03 PM
NISMOFO's Avatar
NISMOFO
Definitely the oil pressure sending unit.
Old Oct 28, 2006 | 12:54 PM
undrgnd's Avatar
undrgnd
I think it's the oil pressure sending unit too. That's funny.
Old Nov 29, 2006 | 03:05 PM
meshugineh's Avatar
meshugineh
Default Got a new oil pressure sending unit
So I bought a new pressure sending unit and I'm going to replace it this weekend. Anyone have instructions or a scan of instructions on how to do it?
Are there specific torque specs etc.?
Old Nov 30, 2006 | 03:51 PM
JonsilvZ's Avatar
JonsilvZ
The oil pump in the Zs are really good. The pressure when starting it up sends the oil way up in the dipstick rubber seal.
Old Nov 30, 2006 | 03:57 PM
Z1 Performance
Former Sponsor
the Z's oil pressure has little to do with the pump, actually
but yes, this car has exceptionally high oil pressures - good tolerances will do that
Old Jan 16, 2007 | 09:20 AM
meshugineh's Avatar
meshugineh
I installed the new pressure sensor. Fixed the problem perfectly and was pretty easy to do.
Also note to those about to change this, removing the sensor results in oil coming dripping out of the engine. Thought I'd help my fellow Z drivers to not swallow oil like me.
Old Jan 16, 2007 | 09:21 AM
meshugineh's Avatar
meshugineh
Default torque settings
Oh and I believe the torque setting was 18, either way lower then my torque wrench so just hand tightening worked fine.
Old Jan 17, 2007 | 08:58 AM
Nismo 350z's Avatar
Nismo 350z
I hope u know that the oil pressure gauge doesnt even read up to 130psi.
Old Jan 17, 2007 | 09:21 AM
97supratt's Avatar
97supratt
5w30? or 10w30? The 5w30's taste like ketchup after a while.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
