rear cooling?
Old Oct 24, 2006 | 05:34 PM
TEK-NIQ's Avatar
TEK-NIQ
Default rear cooling?
Pathy rear cooling mod:
I've searched up and down this forum for more info on this mod, but kept getting threads leading me the wrong way and subjects no where near the info that I want.
I'm looking for an installation instructions, part numbers or so.
I downloaded the FSM off the pathy and found some stuff, but it seems that on the pathy it has alot more plumbing involved with it, I'm wondering how it hooks up to our set up.
will I need all these parts?
if someone can give me a site or price range for the whole system I would appreciated.
TEK..
Attached Thumbnails rear cooling?-pathycoolingmod.jpg   rear cooling?-rearcooling.jpg   rear cooling?-rearcooling2.jpg
Old Oct 24, 2006 | 06:45 PM
overZealous1's Avatar
overZealous1
personally, i just drilled and tapped fittings in and acheived the same thing, minus the thermostat function, for about $4.
Old Oct 24, 2006 | 06:52 PM
Nic@CiNcity's Avatar
Nic@CiNcity
At what point is this mod worth looking into?
Old Oct 24, 2006 | 09:44 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Maybe this thread will help
https://my350z.com/forum/engine-and-drivetrain/195998-rear-cylinder-coolant-bypass-modification.html
Old Oct 25, 2006 | 09:37 AM
TEK-NIQ's Avatar
TEK-NIQ
Originally Posted by Rickdogg
ah, thanx my man. I was sreching for cooling mod, nothing, pathfinder cooling mod..
nothing..
thanx again..
Old Oct 25, 2006 | 05:28 PM
JasonZ-YA's Avatar
JasonZ-YA
Default what else is needed?
Okay, ive looked through all the pictures and read all the info on this mod. take a look at the pics i have? what else is needed? I dont see where welding is needed?
Old Oct 25, 2006 | 05:31 PM
JasonZ-YA's Avatar
JasonZ-YA
Okay, that first picture (post #6) is the 350Z service manual. on the left side. you have to cut the O-ring pipe section off and use hose and two each hose clamps to connect the OEM pathfinder rear water rail? correct?
Also, if you decide to not buy the pathfinder rear oem rail you can just tap your original 350z rail?
see the next two pics?
Attached Thumbnails rear cooling?-imgp0528.jpg   rear cooling?-hose-section.jpg
Old Oct 25, 2006 | 05:40 PM
JasonZ-YA's Avatar
JasonZ-YA
So is that it?
See im thinking of going out and buying the pathfinder unit. From what i gather all i need to do is cut that left side 350Z coolant tube and put a hose section with 2 each clamps on each end to connect to the pathfinder rear rail?
But i have one question? where does item #3 (water bypass hose) on the first picture (350z service manual pic) attach at the pathfinder rear rail?
Does it attach here on the next pic?
Old Oct 25, 2006 | 05:43 PM
JasonZ-YA's Avatar
JasonZ-YA
From what the service manual says, I think the only other thing i need is new gaskets at all the connections and a new o ring at the temp sensor location.
Old Oct 26, 2006 | 10:33 AM
JasonZ-YA's Avatar
JasonZ-YA
okay, ive called one dealer so far? and to do the pathy mod using the pathfinder rear water line, thermostat, fittings and gaskets will cost close to 250 bucks for all the parts.
So, the non thermostate version that OverZealous1 is talking about (pic on post #7) is a low cost alternative for sure?
Old Nov 7, 2006 | 01:08 AM
silver nismo's Avatar
silver nismo
yes and I'm going for it Thanks for all of the guys that supplied a good usefull info all the best and regards...
350Z_Al
Oct 29, 2020 07:44 PM
