Shift Grind at High RPM
Old Nov 3, 2006 | 12:51 PM
shanecrosby's Avatar
shanecrosby
Default Shift Grind at High RPM
I raced an F150 Lightning -and won by a car length! Problem is, I revved exactly to my redline, 7k RPM shifting into 2nd and the tranny grinded during the shift. I did lift my foot off the gas pedal momentarily, no "speed shifting." I have had 5 cars with a manual trans, 2 Hondas, 2 Acuras. No Problems... The Z seems to not go into the next gear when at high RPM very well.. Is there anything anyone can share that they have done to master clean shifts? And yes, I HAVE seen all the threads on bad trannys....
Old Nov 3, 2006 | 12:58 PM
clipso 01's Avatar
clipso 01
i know you've seen the threads....but that my only guess. At first i didn't want to believe that my tranny was one of the bad ones.
My new trans comes in on tuesday.
Old Nov 3, 2006 | 01:57 PM
undrgnd's Avatar
undrgnd
A warmed up and well lubricated tranny shifts a whole lot better. After changing to synthetics and warmimg it up before ******* it, I had no prblems. The first couple of 1-2 shifts in the morning are always acting like they want to grind still though.
Old Nov 3, 2006 | 02:07 PM
Durden76's Avatar
Durden76
I've found that letting the revs drop just a little between 1st and 2nd helps avoid this. Obviously you pay a slight penalty in acceleration (probably a couple 1/100 sec.) but it's much better than missing 2nd gear.
Old Nov 3, 2006 | 02:20 PM
shanecrosby
Does the Z come with full synthetic manual tranny fluid stock? anyone know how much it costs for the fluid change?
sherm
Apr 11, 2020 05:21 PM
Justin100
Nov 29, 2015 03:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
