unusual first gear whine
Old Nov 27, 2006 | 09:05 AM
Bottled Water's Avatar
Bottled Water
Question unusual first gear whine
i have a VERY loud whine in first gear after 3grand. its so loud others tell me it sounds like im s/c. and if i am rolling at like 7-12 mph in neutral and put my clutch in and try to shift into 1st, its really hard to get it in 1st and it whine even w the clutch in. any ideas of why its doing this? and by the way this is my second tranny
Old Nov 27, 2006 | 10:07 AM
97supratt's Avatar
97supratt
Damn nissan transmissions. It's normal if its a whine, mine does it all the time in first. Also on a side note, if you are already rolling at 15mph you should drop it in second not first. If you have to go into first, please rev match then put it into first because otherwise you will grind the synchros and have a hard time getting it in there.
Old Nov 27, 2006 | 10:41 AM
Bottled Water
i know i shouldnt be dropping to 1st at 15 i do it to hear the noise. the noise happen even if the clutch is in is what im saying.
Old Nov 27, 2006 | 10:47 AM
Bottled Water
EXACTLY! do you feel the car slowing down also? i feel some resistance in the tranny when the clutch is in in 1st
Old Nov 27, 2006 | 10:53 AM
edgar350Z's Avatar
edgar350Z
what's "rev-matching"??
Old Nov 27, 2006 | 11:11 AM
LeMans 05's Avatar
LeMans 05
OMG. OK people. The whine is gear noise as your synchros are trying to rev-match for you while you are cramming it into first. First gear is a very short gear, and they have to spool up so they are spinning quickly in order to match up. It results in a whining sound, kinda like a muted type of sound you get from reverse in some cars. Same thing, short gear spinning quickly makes a whining sound. This is the second post recently that has dealt with shifting into first. Good rule of thumb, if it doesn't want to go into gear, it's for a reason. Don't force it.
Old Nov 27, 2006 | 11:25 AM
97supratt's Avatar
97supratt
+1 trillion (use second gear)
Old Nov 27, 2006 | 11:33 AM
97supratt's Avatar
97supratt
Originally Posted by mc350z
i think we are talking about two different things. im talking about the loud whine from 1st gear from a dead stop not downshifting. i agree i never downshift into 1st anyway as along as im in some type of motion its in 2nd
No I gotcha, when in first gear it makes the whining noise. When I got my transmission replaced at 6k miles the new one was awesome. It didn't have a sound except for the typical cement truck noise. A few days later, the whining started in first and I went back into "Supercharged mode". hahah
Its annoying but its something we have to live with, I guess nissan though hey since they are only spending 30K on a Z they can deal with it.
LeMans 05's Avatar
LeMans 05
It's still just gear whine. If it's abnormally loud, maybe you should check your tranny fluid.
Old Nov 27, 2006 | 11:36 AM
97supratt's Avatar
97supratt
My fluid was changed to redline a while back. I think its fine, as long as you have a aftermarket exhaust, you can ignore it.
Old Nov 27, 2006 | 11:40 AM
LeMans 05's Avatar
LeMans 05
One thing to remember, too, the tranny is basically next to your knee. You will hear some gear noise from it, especially with the Z's sound dampening
Old Nov 27, 2006 | 11:42 AM
97supratt's Avatar
97supratt
I think they are referring to the noise that is generated outside the vehicle. Usually when we drive next to a fixed tall object and the sound waves reflect off it and are sent back to us.
Old Nov 27, 2006 | 02:35 PM
knucklez's Avatar
knucklez
i have this problem as well.. quoted from my original post..
mines more like a whine/rattling noise.
Originally Posted by knucklez
When i rev about 4000 rpm on my 1st gear, it sounds like there is something loose spinning (noise sounds like a loose screw spinning around in some sort of circular motion).. The car is brand new and only does this in 1st gear.. Does anyone have a clue what's wrong?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
cashmoney03
Sep 27, 2015 05:24 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
