Help with jack stand
Old Dec 11, 2006 | 06:29 PM
Super Avan Z33's Avatar
Super Avan Z33
Default Help with jack stand
For DIY oil change, it it necessary to put the Z on four jack stand or 2 front jack stand is enough?
Old Dec 11, 2006 | 06:33 PM
first350's Avatar
first350
I only do the front 2 - you might get a little extra oil out when the car is level (4 jack stands), but I doutb there's much difference.
-Peter
Old Dec 11, 2006 | 08:53 PM
drifter23's Avatar
drifter23
I always only jack up the passenger side only. Then when I drain the oil out I lower the jack so, the car is level and most of the oil drips out.
Old Dec 12, 2006 | 03:27 PM
Super Avan Z33
Great tips, thanks a lot guys.
Old Dec 12, 2006 | 03:51 PM
jakesford's Avatar
jakesford
ramps work well too... Much easier
Old Dec 12, 2006 | 04:42 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Just make sure that if you use a jack, you have jackstands as well anytime you are underneath the car.
Old Dec 12, 2006 | 06:07 PM
undrgnd's Avatar
undrgnd
+1 on ramps, much, much easier and infinitely safer.
Old Dec 13, 2006 | 11:29 AM
mg350ZR's Avatar
mg350ZR
on ramps for oil changes. Its much faster and easier.
No need for stands unless wheels have to be removed for brake/suspension work.
Old Dec 13, 2006 | 11:39 AM
VO...'s Avatar
VO...
Administrator
+1
Old Dec 13, 2006 | 02:58 PM
Super Avan Z33
Thanks, yeah...I plan to get one, but not sure am I be able to put my Z up there, b/c I drop my Z on Tanabe GF210 lowering spring. Which one you guys recommend?
Old Dec 13, 2006 | 07:28 PM
rcdash's Avatar
rcdash
on my g coupe, I pulled it onto ramps and then opened the drain valve. I let the oil drain and then just for kicks I raised the rear using a jack so that it was level with the front height and not a single drop more came out... (so I think the slight incline is no big deal).
Old Dec 14, 2006 | 12:25 AM
undrgnd's Avatar
undrgnd
I made my own. 2X12 lumber cut at 45deg angle, start with an 8' length and then progressively shorter boards stacked on top, 6 high gives over 10" of height. Only 2" road clearance needed and you're good to go.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Body Exterior
Nov 9, 2015 10:47 AM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
bighamz
Aug 23, 2002 09:07 PM
